One More Time
Old Feb 1, 2023 | 06:04 PM
PupnDuck's Avatar
PupnDuck
One More Time
In June 2022, after decorating my driveway with engine oil puddles for a year I brought my 2017 3.5 Eco-boost in to the dealer to have the wonderful plastic oil pan replaced under the extended warranty. With another plastic oil pan. Before bringing it in I marked the oil filter with a Sharpie. Sure enough, even though the paperwork showed that the mechanic pulled a new filter from parts he didn't change it. Unfortunately I didn't check until I got home.
So now its been peeing engine oil all over my driveway for the last 2 months again. Brought it back to the dealer today for another oil pan replacement. Plastic I'm sure. Marked the filter again and plan on checking before I leave the dealer this time.
At this rate I'll never have to do another oil change. Every seven or eight months I'll just bring it back for a new plastic oil pan. Apparently Ford actually has a metal oil pan for these engines but if the job is being done under warranty Ford requires the dealer to use the plastic pan or they won't reimburse the service department for any of the repair cost. Way to go Ford....
Old Feb 2, 2023 | 07:13 AM
SpencerPJ's Avatar
SpencerPJ
Hope they get your pan corrected. It's a shame they do this, not all Dealers are the same. I'm not sure I would even assume that new oil is put back in, just sayin.
Old Feb 2, 2023 | 09:55 AM
GlueGuy's Avatar
GlueGuy
Changing the composite oil pan has a very strict procedure. If it's not followed to the letter, you will probably end up with a leak.
Old Feb 2, 2023 | 10:12 AM
Olds64's Avatar
Olds64
That's a bummer the plastic oil pan is so prone to leak.
Old Feb 2, 2023 | 12:28 PM
PupnDuck's Avatar
PupnDuck
Dealer's service department just called. Yep, it's the pan leaking again. They had to order the pan and it just came in - don't know why they just don't order them in case lots! They said they're going to install the pan today but leave the truck on the lift for 24 hours hoping that they get a better cure in the the sealant. They'll fill it up tomorrow, take it for a test drive and inspect it before calling it fixed.
I'll probably be back well before the oil life monitor says I need an oil change. I have 0% confidence in the design or the repair.
Old Feb 2, 2023 | 05:03 PM
JKBrad's Avatar
JKBrad
I would pay the difference to have the aluminum pan installed.
My son-in-law has a 2,7 that started leaking. We were going to do it ourselves, but there isn't a single oil pan available in the country for a 2015-2017. Sadly, there is no metal alternative for the 2.7.
Old Feb 2, 2023 | 05:17 PM
PupnDuck's Avatar
PupnDuck
Unfortunately, there is no difference. According to the service manager, unless they use the exact parts specified in the Ford TSB it becomes an uncovered repair and Ford will not reimburse them for the repair. The going rate for the work is about $750. I'll bring it back every 6 months if I have to just for the pleasure of seeing the look on the service manager's face. And the free oil change.
Old Feb 3, 2023 | 09:20 AM
Olds64's Avatar
Olds64
Make sure you mark the oil filter like you mentioned in the original post. Don't want them to skip out on parts they owe you.
Old Feb 3, 2023 | 12:30 PM
PupnDuck's Avatar
PupnDuck
WooHoo!
Free oil changes for the next couple of years!
Since this was a repeat of a previous repair, the deductible on my Ford ESP plan didn't apply. No charge. I've got two and a half more years on my warranty so given the reliability of the plastic pan repair I guess I can count on getting new oil and filter every 8 months or so. They put fluorescent dye in the oil so next time it will be easier to spot.
Way to go Ford!
Old Feb 3, 2023 | 08:41 PM
Saxon's Avatar
Saxon
Man that sux.
Come on Ford and stand by your name.
scott.butler4
2015 - 2020 F150
Aug 16, 2022 06:20 PM
c04678
6.7L Power Stroke Diesel
15
May 28, 2018 10:51 AM
dbagg
Nov 16, 2012 05:42 PM
landstroker51
Oct 30, 2005 07:37 AM
rett8799
3.8 & 4.2L V6
Jan 19, 2005 06:59 AM
