Driveshaft question
Old Jan 31, 2023 | 07:21 PM
Jeff Wecker's Avatar
Jeff Wecker
Driveshaft question
I have a puzzler here..... My 1990 F150 4x2, has a 133" wheelbase, and a 1 piece aluminum driveshaft. My recently acquired 1986 F150 4x2, is also 133" wheelbase. BUT, it has a 2 piece drive shaft with midship bearing. Both my trucks have the 5.0 engine, and code T AOD trans. Why would one truck come with a 2 piece, and one not? Were the 2 piece ones in the F150's done away with, after 1986?
Old Jan 31, 2023 | 07:53 PM
Teabag's Avatar
Teabag
Trailering
Probably to cut costs is my guess.
I know the one peice shafts are harder to balance, and easier to pretzel hitting a rock or under alot of torque. Two piece are much better in my opinion.
All my 90's regular cabs were one peice.
Old Jan 31, 2023 | 09:13 PM
Nothing Special's Avatar
Nothing Special
Did 1990 trucks come with aluminum drive shafts? I thought they were all still steel at that point. So I wonder if some time in the last 33 years someone put a new drive shaft in that truck and chose not to do it the same as stock.
Old Jan 31, 2023 | 09:15 PM
Teabag's Avatar
Teabag
Trailering
Mine were all steel. 93 through to 96
Old Jan 31, 2023 | 09:34 PM
Prototypemech's Avatar
Prototypemech
My 2001 f350 powerstroke cab&chassis has an aluminum 1 piece drive shaft. I wonder if the PO grabbed a drive shaft from a later model truck.
Old Feb 1, 2023 | 05:43 AM
GNR22's Avatar
GNR22
I've never seen an aluminum driveshaft on an OBS. Assuming Prototypemech is on the right track. Probably threw a shaft at some point and found an aluminum shaft that was close enough.
Old Feb 1, 2023 | 09:08 AM
Jeff Wecker
The aluminum shaft in my 90, had original Ford U joints in it, so either the PO did adriveshaft swap, or they ran out of steel shafts on the assembly line, and used what they had on hand
Old Feb 1, 2023 | 12:13 PM
Mikulh's Avatar
Mikulh
My '91 2WD, Short Bed, Single Cab F150 has a one piece steel driveshaft.
Old Feb 1, 2023 | 04:56 PM
Mudsport96's Avatar
Mudsport96
89 f250 LD 5.0 5spd 2wd reg cab long bed had aluminum
my 95 150 reg cab short bed 4x4 has steel
89 e250 had steel
Old Feb 1, 2023 | 05:49 PM
Chris Bornhop's Avatar
Chris Bornhop
4wd Low
Driveshaft help please
Hello I have a 1993 Ford f150 XLT lariat extended cab with the wheelbase of 133. 5.0 motor n 8.8 rear differential rear-wheel drive aod transmission and I cannot find the 4-in aluminum drive shaft that came standard on my truck it is 70.5 in from the furthest part of the u-joint to the other for this part of the u-joint. I cannot find this part anywhere at local junk yards recycling centers etc and the only ones I'm finding online do not want to be for the aod transmission only the e4od transmission and they're also wanting close to $700 a piece can anybody help me in a finding this part or b answering for sure whether or not I can switch my one piece aluminum drive shaft to a two peace drive shaft any and all help is greatly appreciated thank you
Old Feb 3, 2023 | 03:12 AM
TexasGuy001's Avatar
TexasGuy001
The only trucks I have seen with an aluminum driveshaft are 2wd 5.0 AOD or 4R70W in the regular cab long bed configuration in 87-96 with 8.8 rear end. An 86 has a 9 inch rear I believe.
gogoat
Aug 20, 2021 08:37 AM
ryans88gt
Nov 30, 2013 06:44 AM
Fordracing30
Feb 12, 2012 06:43 PM
90f150302
Mar 3, 2010 09:18 PM
53ford
Apr 1, 2009 07:33 AM
