Driveshaft
Old Aug 18, 2021 | 01:40 PM
gogoat's Avatar
gogoat
Driveshaft
How far into the transmission does the drive shaft need to go? also if I push it all the way in I can wiggle it up and down a little bit. This is a 90 ish aod.
Old Aug 18, 2021 | 03:19 PM
Conanski's Avatar
Conanski
The splined yoke should have about 3/4 of it's length inside the trans tailshaft and it should not be bottomed out when bolted to the rear axle. In my experience some movement in the shaft doesn't seem to be unusual, if it doesn't vibrate or leak you are good. Also the spline doesn't get lubricated by the trans and should be greased at assembly.
Old Aug 20, 2021 | 08:37 AM
gogoat's Avatar
gogoat
Thanks alot
gogoat
Aug 18, 2021 02:41 PM
DagenhamDave
Dec 15, 2014 10:05 AM
68shortbedmo
May 25, 2012 03:48 PM
90f150302
Mar 3, 2010 09:18 PM
hotrodford_88
Sep 25, 2000 08:47 PM
