Sponsored by: Real Truck
COP Screw Broke.
Old Jan 27, 2023 | 07:43 AM
Black Wishbone's Avatar
Black Wishbone
3rd Gear
COP Screw Broke.
Hi all, I am new to this forum, I just picked up a 2001 F350 5.4 truck with a p0304 code. Really didn't think it would be that big of a deal until I went to test the coil and found it loose. A little more investigating and found out that the screw head is broken off. Now of course this is for #4 and a real pain to get to. I live in the northeast so the weather is not great for spending hours working on a truck and I do not have a garage to get it into. So my question really is do I try to fight with it, and hope to get tips from you guys or just bring it to a garage and hope they deal with it correctly. While I am at it I will most likely replace all 8 plugs and coils. If I do it myself at least for right now only replace #4.
Thanks in advance Steve
Old Jan 27, 2023 | 08:51 AM
Djosbun's Avatar
Djosbun
What do you mean “try and fight with it”? Yes, you need to remove it to properly affix a replacement coil. Throw some heat at it and drill it out or we’ll a nut to it.
— Dave
Old Jan 27, 2023 | 09:47 AM
Black Wishbone
3rd Gear
I know I need to remove the screw and replace it properly that was not the question. The issue is I can hardly touch the broken screw, never mine get tools or heat on it correctly. This is Cylinder #4 up against the firewall. I can start ripping thing apart but the may lead to more broken stuff and more time. Time and weather are not what I have right now.
Old Jan 27, 2023 | 09:31 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Get a piece of closed cell foam like neoprene. Wedge it between the top of the coil and under the fuel rail. It should hold it until you have time to properly remove the broken screw.
If you don’t wanna do that yiu can try predrilling next to the original screw using a angle bit drill and then screwing in another screw. I’m not sure how much space you have. I did it on a crown vic. I have extra COP screws if you need some
Old Jan 28, 2023 | 07:57 AM
user 195474726373's Avatar
user 195474726373
Last year I replaced a COP and somehow forgot to put the screw back in. I drove several thousand miles with no problems. I just happened to notice it one day. But I had no check engine light.
Old Jan 28, 2023 | 08:06 AM
madsonp's Avatar
madsonp
Do you have any pictures of the broken screw you could share ?
Old Jan 28, 2023 | 08:38 AM
user 195474726373
Can you get a small C Clamp on it?
Old Jan 30, 2023 | 07:28 AM
Black Wishbone
3rd Gear
Thanks for all the suggestions. I just realized I was suppose to have sent this yesterday. While it was a nice day yesterday I decided to give it a go again. This time with the best tool I have for such a thing vice grips baby ones at that and some liquid wrench. I still could not get close to getting a good bit on the screw or and when I did get it a little bit I had no room to turn it.
I have a call into a garage see what they can do for me.
Danglewang
1997 - 2003 F150
Oct 20, 2017 09:00 AM
zamunda
1997 - 2003 F150
Apr 5, 2011 11:58 PM
Historichouseguy
Sep 7, 2008 12:19 PM
fishinfool98
1997 - 2003 F150
Mar 12, 2008 04:44 PM
StevePA
1997 - 2003 F150
Mar 11, 2003 02:48 PM
