Sponsored by: Auxito
01 5.4 coil problems
Old Mar 12, 2008 | 12:53 AM
fishinfool98's Avatar
fishinfool98
trying to take the coils out to change the plugs and the bolt on the #6 coil is just spining and I have tried everything to try and get it out with no luck
thanks
Ryan
Old Mar 12, 2008 | 10:34 AM
mjunk1's Avatar
mjunk1
A long skinny screwdriver under the flange on the head might give you a little upward pressure while turning it? Hard to say, but you might be able to build something to pry on by placing a socket or something in there.
Good luck.
Old Mar 12, 2008 | 04:44 PM
fishinfool98
well i got it out but ruined the coils mount in the process
i ended up getting a pait of snips and working it out bit by bit
once out put loctite on the colet
had a spare coil is the only reason for taking it out that way
even prying up on it and trying with an electric 1/4in impact wouldnt get it out
thanks for the reply
