Looking for maf sensor multi meter values.
Old Jan 26, 2023 | 12:46 PM
jetedwards's Avatar
jetedwards
Hi ive been on this for a couple days now. Got 2 codes 1 was iat and other which i still have is maf in range but low... I got rid of the code for iat think my wire was broke so i put new lead in female harness. I am getting a reading of . 49 or . 56 g/s air flow. It will not change while driving. Also it reads the same with truck running maf disconnected.... I put in a new maf no change. At this point in try to establish that the wires goin to are in tact...
​​​Values i get from harness left to right are. Ground then 13.6v then ground then 7.00v then 0 then 5v... Id like to know what value the 2nd is supposed to have... Im lost... Since i fixed the iat number 1 issue the truck is drivable.
no tuner and the egr is deleted
Old Jan 27, 2023 | 08:07 AM
Yahiko's Avatar
Yahiko
What year truck? I can try and pull up the pinpoint testing.
The MAF sensor is a hot wire type sensor.
I am fairly sure you won't get readings with a DMM.
Old Jan 29, 2023 | 05:11 PM
jetedwards's Avatar
jetedwards
Hi thanks its all set now... It was my sending unit screen broke off .. so i was pullin air in when my tank got below a qtr. So the code is still there but i dont care bout it as my truck is running good
Old Jan 29, 2023 | 06:07 PM
bismic's Avatar
bismic
From the PC/ED manual (volts):
MAF 0 KOEO
1.44 Low Idle, 690 rpm
2.65 High Idle, 1200 rpm
1.98V Light Acceleration
2.2V Cruise
4.23V Hard Acceleration
1.68V Coast
0.5 - 4.75 Operating Range
Old Feb 4, 2023 | 03:03 PM
jetedwards's Avatar
jetedwards
Thanks a lot
AndeyHall
Jul 16, 2012 01:15 AM
bob8619
Apr 22, 2012 03:58 PM
penman39
1983 - 2012 Ranger & B-Series
Apr 28, 2006 01:47 PM
moat
Aug 17, 2005 05:15 PM
