Clunk When Lifting Off Light Throttle
Old Jan 26, 2023 | 09:36 AM
YeeOlDentside's Avatar
YeeOlDentside
4wd Low
I daily a 1977 F150 RWD 3speed-Auto supercab longed, that has starting to make a clunking sound.
When applying light throttle, 30% or less, and lifting your foot off, there is a clunk. Sometimes this clunk is immediate, ans sometimes this clunk is delayed by a second or two. This clunk sometimes feels like it's comin from under your butt (middle of the cab) , and sometimes almost feels like it's coming from the front driver's side. It's more recently been feelin the latter.
I should also add, that when shifting into R from P, after havin er sit, it shifts quite nicely. However, after driving the truck, and shifting D to R, N to R, P to R, it is quite a hard shift into R. I have read that this is just an ol Ford auto thing, but im also thinkin the clunk could be related to this.
I have worked on numerous vehicles, old n new, but am new to Dentsides. In my mind, I think of ujoints and Im also thinking kingpin, just because it sounds like its coming from the front? Does that make sense, or is there something else I should be lookin at/for?
Any help would be appreciated!
Old Jan 26, 2023 | 10:13 AM
mwoj's Avatar
mwoj
It sounds like U joints to me. If you can, slide under the truck and try and move the driveshafts around near the u joints. If they’re really bad, you’ll get movement at the u joint itself. If none of them move, you may still have a bad u joint. Sometimes they will look fine but are actually binding and heating up while driving. If you have a laser thermometer you can sometimes pinpoint a “hot” one after driving.
Old Jan 26, 2023 | 11:21 AM
tbear853's Avatar
tbear853
My'77 C-6 auto will do it if I've just gone up the hill to the intersection in 1st, then 2nd after exiting my driveway, and then before it goes in third, I let off because of the stop sign, it shifts into 3rd ... and it could be described as a clunk. Not a hammer or metalic type clunk, just a firm clunk under no load.
It's normal ... now for over30 years. It got a shift kit in the '80s.
Old Feb 1, 2023 | 05:08 AM
Ozzie H.'s Avatar
Ozzie H.
Sounds like a bit of "looseness" in something. Check front end suspension & steering, U-joints, and engine mounts.
Old Feb 1, 2023 | 09:06 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 insp drive line u joints, eng and trans motor mounts.
Old Feb 1, 2023 | 09:12 AM
jtrux's Avatar
jtrux
Without looking at it, I'd vote carrier bearing.
Old Feb 1, 2023 | 09:34 AM
77&79F250's Avatar
77&79F250
Now I slow down and read...Super cab long bed. X3 on drive shaft carrier bearing.
Old Feb 2, 2023 | 09:38 AM
YeeOlDentside
4wd Low
I recently started hearing a mild humming sound coming from the rear middle of the truck when cruising at highway speeds. I purchased a new carrier bearing, and the 3 Ujoints as I mine as well replace them when the whole thing is out.
I wil update with the results!
Old Feb 2, 2023 | 12:43 PM
Westcoast Highboy's Avatar
Westcoast Highboy
And don't forget to lube the slip joint while you have it apart. Sometimes a binding slip joint will also cause the issue you described.
Old Feb 2, 2023 | 05:16 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
X3 U-joints.
Dale mckenzie
6.7L Power Stroke Diesel
Mar 7, 2015 07:34 PM
Banjobanger
13
Jul 6, 2014 10:06 PM
grantpage
Oct 4, 2011 05:49 PM
waverunner800
6.4L Power Stroke Diesel
23
Jun 10, 2011 12:26 PM
ripcurl94
Aug 23, 2006 07:13 AM
