AC Clutch removal
Old Feb 2, 2023 | 08:35 AM
Shiner1971's Avatar
Shiner1971
AC Clutch removal
I’ve got a 77’ 150 with a factory installed air conditioning compressor
I’m working on trying to get the clutch off and can’t find the right puller
its a tall square compressor with 4 bolt holes in both sides
R12
any help is greatly appreciated!!ii!!
Thank You in advance
Old Feb 2, 2023 | 09:32 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get deep in the OEM manual on this one, I remember reading that you must electrically engage (?) or disengage the clutch before removal to prevent damage.
Old Feb 2, 2023 | 09:39 AM
Mark8man's Avatar
Mark8man
I recall mine coming off pretty easy but a little foggy to be 100% certain how I did it but here goes. Remove the center retaining bolt, see if the hub has large female threads. I believe it is 5/8x11 thread if memory serves. Find a 5/8x11 bolt maybe a couple inches long and thread it in. It will contact end of compressor shaft and pop the pulley right off.
Old Feb 2, 2023 | 05:36 PM
Shiner1971's Avatar
Shiner1971
Thank You
It does have a 5/8 thread
below that is shaft end of the compressor
I figured that I could do what you did but
problem is I cant keep the thing from spinning
so I think I need a sleeved arbor or pulley remover different that the one oriellys sold me
Old Feb 2, 2023 | 05:38 PM
Shiner1971's Avatar
Shiner1971
I appreciate your help
[QUOTE=Mark8man;[url=tel:20728363]20728363[/url]]I recall mine coming off pretty easy but a little foggy to be 100% certain how I did it but here goes. Remove the center retaining bolt, see if the hub has large female threads. I believe it is 5/8x11 thread if memory serves. Find a 5/8x11 bolt maybe a couple inches long and thread it in. It will contact end of compressor shaft and pop the pulley right off.[/
Im gonna go try it again
bigtower2018
May 24, 2021 09:36 AM
poffutt
1978 - 1996 Big Bronco
Mar 22, 2010 04:33 PM
spdjunke
Aug 8, 2005 09:56 AM
masseysbronco
Jul 26, 2005 02:22 PM
markcrane
Aug 4, 2003 12:26 PM
