Hello from Germany
Old Jan 23, 2023 | 10:34 AM
Don Naslund's Avatar
Don Naslund
If you find one here in the U.S., you should look at trucks from the west coast because there is usually less rust, maybe someone from this site can go look at it for you. Fly over here, buy it and load it with spare parts and ship it back home.
Old Jan 23, 2023 | 10:32 PM
wyrm73's Avatar
wyrm73
If you really want a F250, but don't like the quirks of the highboys and don't like the look of the 78-79- it is possible to swap grilles from a 73-77 onto the 78-79. I haven't done it myself, but the process doesn't look terribly difficult to do. Access to parts might be the difficult part for you, making sure to get all the small pieces and whether it is worth the shipping. Just another option to consider. Check out this link: https://www.ford-trucks.com/forums/1...rill-swap.html
Old Jan 24, 2023 | 07:27 AM
beardedcap's Avatar
beardedcap
Originally Posted by Patpät
Hi,
I found that (official?) Ford brochure and thought I got all the weights things right..
Page 11, Regular Cab, 8ft bed, F150 for example:
Deisred payload: 2245 lbs , what is something about 1000kg
https://www.xr793.com/wp-content/upl...rd-Pickups.pdf
Do I have a false interpretation of "Desired payload" ?
No, I think you're right. I'm just way off I guess. I didn't know the F150 was ever rated for such a high payload
Old Jan 24, 2023 | 03:50 PM
Patpät's Avatar
Patpät
Hi,
would be really nice to get some help from the members here when things are getting serious. Especially because I want one that's as stock/original as possible. Or at least with the right spare parts. That's because of the german "Oldtimer" issue. I for sure will need some expert help here.
Even if the F150 can carry the desired load, maybe I should go deeper in the '78 & '79 dent. Could be an option though, if it is as easy to work on and does not have more modern or electric features than the ones before. You remember: As less beeps and signals and electric stuff as possible.
Shipping or getting parts at all will be the most interesting part for me, indeed
Thanks so far
Patrick
Old Jan 24, 2023 | 10:16 PM
cwegga's Avatar
cwegga
I don't know if he has a username here, but you might try contacting Simrokkz over at fullsizebronco.com. He has done what you are talking about in the last few years with a 2nd gen Bronco. He would probably have insight into shipping, complying with your version of antique registration and other things. I know he had issues I wouldn't have expected like needing wheels with some rating or certificate paperwork or something that we don't require over here so aren't easy to get. This is his build thread https://www.fullsizebronco.com/threa...-steps.509746/ I tried to see if he had the same username here, but he doesn't appear to.
Old Jan 27, 2023 | 03:57 AM
Patpät's Avatar
Patpät
Hi,
that's interesting. Thanks for that hint and for checking out.
Yes, in Germany we have some more regulation what is allowed on vehicles.
Due to that, the question regarding the rims, and as a consequence the options of certificated tires, seems important to me. We cannot install every tire on any rim.
In concrete words: 5 lug will most likely bring more options than 8 lug will, I would guess.
So in the best case, I can get some original, coeval rims size , that are german certificated tires available for.
Old Feb 17, 2023 | 09:08 AM
Patpät's Avatar
Patpät
Hi folks,
hope everyone is doing fine.
One question to the rear window. In general I like the idea of driving around in summer with the rear window open just right behind you. But 2 things made me think about it closer:
1. I read about problems with water leaking in. That seems to be a chance of 50:50. Some have problems, others not. So the safer way would be a solid one. Especially for me with my situation getting spare parts.
2. Seems that a slider is not really lockable? There's just something like a hook? Hard for me to guess, if this is safe or it it's easy to open it from the outside? Again, safer way here, the solid one I guess?
Greetz
Patrick
Old Feb 17, 2023 | 11:46 PM
nutter3's Avatar
nutter3
You can find a metal latch. The plastic ones break way too easy. To really defeat the opening of the slider from the outside, a couple wooden dowel rods laid in the inside track will work.
C.R. LAURENCE DVL2 CRL Replacement Metal Backslider Latch
Old Feb 18, 2023 | 10:02 AM
Don Naslund
Yes, the rear sliding window is easily opened from the outside with a small pry tool like a screwdriver,
Old Feb 18, 2023 | 12:34 PM
Westcoast Highboy's Avatar
Westcoast Highboy
My truck has the factory sliding rear glass and is latched with a metal clasp which is very sturdy. A person could potentially break in by jamming a screw driver in there but they could also just throw a rock through the window if they wanted to break in that badly so I wouldn't worry about that.
As for leaks, my rear slider leaks around the dry rotted outer rubber seal, exactly the same as previous old Fords I owned that had the solid glass rear window. I've got a new rear window seal to install once the weather warms up sufficiently and that should solve the leaking problem. Nothing beats cruising down a country road in the summer with the rear slider open. Plus its much easier to toss your empty beer cans in the box with a slider ( just kidding, maybe.... )
Old Feb 21, 2023 | 03:50 AM
Patpät's Avatar
Patpät
Hi,
thanks for your replies.
Getting rid of the beer cans .. that's definitly a plus I hadn't thought about.. !
I really like the idea of an open rear window, but the more I look at some pictures, the more I brood which look i prefer. The solid rear window seems a bit more classy and clean..
Maybe it depends, how the truck looks like in general , the style.
Best regards
Patrick
Old Feb 22, 2023 | 09:41 AM
WorkingStill's Avatar
WorkingStill
Hi,
Best regards
Patrick
It's all personal preference, but I can tell you from first hand experience having the slider is better than not. My '78 has a slider; my '13 does not. I'd prefer the newer truck have an opening window as well. Just helps so much with venting the cab, and this is even more welcome in the older trucks if you don't have A/C.
Old Apr 13, 2023 | 04:43 AM
  #28
Patpät's Avatar
Patpät
Hi folks,
job and house projects kept me busy the last weeks. Time to get back to hobby things..
A few days ago I visited George (MrGGermany). Could take a close look at a dentside for the first time, ask some questions and the best part.. drive it! (Thanks again George) It was awesome. Much much better than I expected. Just neat. Great feeling and flair..
George also told me that heat is a thing in the cab, so I think the sliding window would be a nice feature.
Another point now is the transmission. I thought manual shifting would be the right thing when driving an old truck, but as George's is automatic and that really was great to drive, I should not exclude that as an option. And the clean cab floor was nice too.
I hoped there were some information about pros and cons, recommendations regarding auto or manual, but maybe I just didn*t find it.
Can anybody help me here?
Buzzwords: Variations, driving smoothness durability, maintenance, towing/loading, 4wd ?
Have a nice day everyone,
Patrick
Old Apr 13, 2023 | 05:42 PM
  #29
Westcoast Highboy
I have owned both. Had a 77 F150 4x4 with 351m and 4 speed. It was rough looking as I bought it from a logging company (I think the right side door and front fender were the only straight panels on the truck) and I personally prefer the 4 speed transmission as I enjoy driving standard transmissions.
That being said, my previous 77 F250 Highboy and my present F350 Camper Special was/are both C6 automatic transmissions behind 460 cubic inch motors.(Highboy was originally a 400 but had a Lincoln 460 swapped in) which I also thoroughly enjoy driving. The automatic is certainly easier when trying to drive while holding my coffee cup 😜
I’ve always found these old trucks a bit sluggish with an automatic but when powered by a 460, they get up and go. It comes down to personal preference. I would focus on finding the nicest truck you can regardless of whether it is manual or automatic, I’m sure you will enjoy it either way!
Old Apr 13, 2023 | 05:57 PM
  #30
beardedcap's Avatar
beardedcap
I've always heard the C6 uses like 40-60 HP, when these trucks were only making like 150-200 hp you feel it
