No Separation plate needed???
Old Jan 21, 2023 | 10:07 AM
El Huapo's Avatar
El Huapo
4wd Low
Unhappy No Separation plate needed???
Separation Plate Question on a 302 w/C4: I have an '89 engine which I'm trying to get running. Used vehicle and the old owner is passed away so I have no info on where which parts may have come from. The flexplate balance weight is hitting the separation plate when I try to manually rotate the engine. Now the C4 has the starter mounting bolt holes and everything looks good there. If I delete the separation plate altogether will it cause me problems? Maybe put washers between the starter and trans bell with the mounting bolts to simulate the plate spacing?
Old Jan 21, 2023 | 10:46 AM
kevinv10's Avatar
kevinv10
I might be wrong, but if the flexplate balance weight is hitting the separation plate, I think the flexplate is in backwards. But, it has been a while since I worked on this setup.
Old Jan 21, 2023 | 12:03 PM
wwhite's Avatar
wwhite
Probably wrong flexplate.
Old Jan 21, 2023 | 12:19 PM
FuzzFace2's Avatar
FuzzFace2
I would also say flex plate is the issue
And you must run the motor mid plates as it locates the starter.
The lip around the starter fits into the plate to hold it in place just the starter bolts dont cut it.
FYI small blocks use a different motor mid plate between manual & auto transmissions on the older trucks so guessing the same with the 87> trucks.
Dave ----
Old Jan 21, 2023 | 12:39 PM
My4Fordtrucks's Avatar
My4Fordtrucks
C4 is an interesting transmission choice for a full size truck.
Old Jan 21, 2023 | 12:49 PM
El Huapo's Avatar
El Huapo
4wd Low
This engine is a transplant into a '52 ford sedan and not very well done at that. I came originally to this forum because I thought the engine was from a truck. I got great replies to my other problems so I like this forum. Hope no one gets too upset that I ask my ignorant questions here, seems like a knowledgeable place.
jas88
Jul 4, 2022 08:24 AM
wasowski
Aug 12, 2012 12:53 AM
JoryCustomSolutions
Oct 18, 2009 10:18 AM
86f15035s
Dec 10, 2007 07:01 PM
john fin
Jun 13, 2007 08:41 PM
