94 Trailer Lights Troubleshooting
Old Jan 19, 2023 | 05:00 PM
R&RFord's Avatar
R&RFord
When I bought my truck it had a RV style 7 pin outlet and a 4 pin flat outlet.
For whatever reason the 7 pin used some of the available factory wiring but they ran their own trailer brake feed and battery charge wires. I don't remember ever having a problem with it, but I haven't used it in years.
The 4 pin outlet is a t connector into the regular lighting harness.
I have set about setting up the 7 pin to use the factory wiring. I made a plug and play harness and got it installed today. When checking signals the turn signals have very little power, almost not showing on my meter. Marker lights and battery charge circuits checked out fine. Couldn't safely check reverse by myself and I am waiting for the new controller to check the brake signal.
I pulled the fuses for the trailer turn signals and checked the power there and got the same result. Almost no power. The trucks turn signals work fine and the turn signals on the 4 pin trailer plug work great.
Not sure what to check next. Your thoughts and suggestions would be helpful. Thanks!
Old Jan 20, 2023 | 01:22 AM
wwhite's Avatar
wwhite
Connector 202 and 205, under hood, near firewall/brakebooster/fuse box.
Basically, they are tapped into your turn signal for vehicle, then run to the fuses.
Look for wire colours of LightGreen/Orange(LG/O), and Orange/LightBlue(O/LB).
(first colour is solid / second colour is the stripe)
Old Jan 20, 2023 | 07:31 AM
R&RFord's Avatar
R&RFord
Thanks for responding!
If I am reading the diagram correctly the 2 circuits go out of the cab to the fuse box and then back into the cab and then back out of the cab again to the harness going down the driver side frame rail...
I will start with continuity testing... see if I can find the problem.
Old Jan 20, 2023 | 11:52 AM
R&RFord's Avatar
R&RFord
So, there is a pin mismatch between the engine side and the cab side of C202. This is not a huge surprise as I swapped the main engine harness out a few years ago.
However, almost all of the wires are the wrong color on the replacement harness according to pin outs I have, which is hurting my head.
On my engine side C202 I have
Pin 1 - R/T
Pin 2 - R/B
Pin 3 - DB/G
Pin 4 - P/T
Pin 5 - Unused
Pin 6 - R/Y
Pin 7 - BK/G
Pin 8 - Unused
Pin 9 - R
Pin 10 - P/B
Pin 11 - BK
Pin 12 - Unused
From what I could find this doesn't match any other C202 diagram from a 94 or 95... thoughts?
Old Jan 20, 2023 | 05:07 PM
R&RFord's Avatar
R&RFord
Given that the truck runs without any trouble, I started testing for function at each pin location, and so far everything is right... just wrong colors. No idea what that is about.
I was mistaken about the pin mismatch at C202. I wasn't paying enough attention to what I was doing.
I put it all back together to move the truck, and now the trailer turn signals are working, so guess it was just a poor connection at C202 or C205.
Going to leave it alone until I encounter another problem.
Old Jan 20, 2023 | 08:23 PM
wwhite's Avatar
wwhite
I'd take the connectors apart again, and clean with wire brush.
That's good. Most electrical issues are 99% bad ground connections.
off2fsh
Jul 25, 2021 05:03 PM
Daveyj
Apr 24, 2014 05:44 PM
Randomsht
Mar 28, 2014 06:46 PM
SUPERDUTY OUTLAW
All Things Towing
Jan 11, 2009 02:21 PM
UWMtriebs
Jul 18, 2008 03:52 PM
