Trailer Harness Help
Old Jul 25, 2021 | 02:34 PM
off2fsh's Avatar
off2fsh
Trailering
Question Trailer Harness Help
Recently my trailer lights on the passenger side stopped working, Checked for broken wires, all is good. Went to the plug itself on the X, Left side has power but not the passenger side.... lights work on the X no problem there.
could there be a fuse that controls trailer plug output?? Driver side and passenger side.... Or is this a case of back tracing all the wires???
Any thoughts and suggestions greatly appreciated... Thanks
Old Jul 25, 2021 | 03:59 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by off2fsh
Recently my trailer lights on the passenger side stopped working, Checked for broken wires, all is good. Went to the plug itself on the X, Left side has power but not the passenger side.... lights work on the X no problem there. ....
What year? There were wiring changes in 2002, but may not affect the trailer wiring.
On a 7-pin trailer connector pin #3 provides power for all the running lights - left & right.
Pin #5 is power for the left turn signal and brake light.
Pin #6 is power for the right turn signal and brake light.
Are you having a problem with the running lights or the turn signal/brake?
In 2002, fuse 2.6 in the CJB provides power for both trailer turn signals, there are separate relays for the R & L turn signals.
The Right turn signal relay, K352 is in Aux Relay box 4.
Old Jul 25, 2021 | 04:08 PM
off2fsh's Avatar
off2fsh
Trailering
X is a 2000, problem is the passenger side, signals, brakes, and running lights.... I found where there are two fuses, one for rt and one for lft, only for triler harness
changed both fuses #20 and 22... lft works rt don't... ????
Old Jul 25, 2021 | 05:03 PM
off2fsh's Avatar
off2fsh
Trailering
Problem solved... thanks to all that responded... Amd thanks to such a great forum...
Gerby Dutchy
2009 - 2014 F150
Mar 20, 2015 04:18 PM
akpolaris
Nov 6, 2010 05:05 PM
GRB1
Oct 17, 2008 08:08 AM
s2gots
Nov 29, 2007 11:12 PM
buttz
May 17, 2007 05:44 PM
