No trailer stop/turn signals
95 F250 with original factory 7 pin trailer harness. Parking lights work on the trailer, but no stop or turn signals. I checked power distribution box under the hood and fuses 4,6, and 7 are good. I tried swapping relay #4 with 3 spare relays I had but no luck. At the 7 pin connector I have power to parking lights, power to trailer battery, ground. Pretty sure trailer brakes have power also. Anyone have any suggestions? Thanks in advance.
Sounds like you have a broken wire on the lead that feeds the brakes and turn signal lights, I would crawl under the truck and trace those two systems, if you can't find it, it would not be difficult to run new wires from the rear of the truck to the plug, one from each light should do it.
Found my issue. Engine compartment harness does not match up to in cab harness at firewall. The large 72 pin (I think) harness has the yellow and green coming from power distribution box and loops in the cab over to the 24 pin (trailer, fuel pumps, rabs etc) harness and straight to 7 pin trailer plug. Cab side green and yellow are locations 61 and 62, engine compartment side they are at 65 and 72. I am gonna cut them and splice today. Now I know where to start looking to get my temp and oil pressure gauges to read properly.... Thanks to Subford for the wiring schematics.
fordtrkpuller
03-15-2021 06:35 PM
Pat Thomson
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-06-2015 07:27 PM
