ASAP F550 weight
Old Jan 12, 2023 | 10:22 AM
radhaam's Avatar
radhaam
2nd Gear
ASAP F550 weight
Hello,
I'm trying to get transported f550 with a body on it, anyone has any idea what might it weight? Will it be over 13000 lbs?
Old Jan 12, 2023 | 11:51 PM
85e150's Avatar
85e150
Thread moved--I'm not sure what year that is, but it appears to be '17+.
OP was in the wrong place.....
Old Jan 13, 2023 | 04:02 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I'd be more than willing to bet it's over 13,000#
Old Jan 13, 2023 | 04:53 AM
OverheadCram's Avatar
OverheadCram
C&C is 8,200lbs before upfit. I could see it being 13k or over easily.
Old Jan 13, 2023 | 05:17 AM
senix's Avatar
senix
empty or with tools?
Old Jan 13, 2023 | 06:19 AM
1olddogtwo's Avatar
1olddogtwo
My two-wheel drive f550s with flatbeds weigh 10.500.
I would put that close to 15,000 lb being four-wheel drive with the bed crane, welder and the front bull guard
Old Jan 13, 2023 | 06:22 AM
ToMang07's Avatar
ToMang07
I imagine that's well over 13,000lbs.
Old Jan 13, 2023 | 08:55 AM
KeystoneF350's Avatar
KeystoneF350
Why not run it across a scale at a local truck stop? Looks like there's a Pilot with a Cat Scale down the road from you at Bentleyville on I-70.
Old Jan 13, 2023 | 10:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
If I had to guess:
Truck about 8000.
Palfinger crane about 2400.
Service body about 4500.
15k seems like a reasonable WAG.
Old Jan 13, 2023 | 12:28 PM
Keokie's Avatar
Keokie
I printed out a pic of it on photo stock paper. I weighed the photo, then ran a series of equations, factored for temperature and time of day, and came up with 14,631.367lbs.
Seriously though, for transporting it, I would definitely get it weighed. I'm guessing you may not be near the truck. Perhaps someone could weigh it for you? The only other thing is to get the info from all than manufacturers of the equipment added and do the calculations. Still, I would be hesitant to trust those numbers.
Old Jan 13, 2023 | 02:42 PM
406f150's Avatar
406f150
My dad's F-450 Extended cab with service body, crane, welder, and loaded with parts and tools is 16,500 on the scale. I would also guess around 15k on that with empty boxes.
Old Jan 13, 2023 | 04:00 PM
4wd6.7L's Avatar
4wd6.7L
Don't upfitters adhere a revised load sticker in the jamb, or is that not really standard procedure?
Old Jan 13, 2023 | 08:32 PM
UGA33's Avatar
UGA33
I’d put it at 15k as it sits without tools.
Old Jan 14, 2023 | 06:47 AM
1olddogtwo's Avatar
1olddogtwo
I used the same formula except I did it under the midnight moonlight, came up with 14,577.69
Old Jan 14, 2023 | 11:05 PM
Keokie's Avatar
Keokie
Tried that and can confirm midnight moonlight at 14,577.69.
bigwin56f100
Jan 3, 2023 03:34 PM
CharlyG
Nov 29, 2016 02:46 PM
BigF350
6.7L Power Stroke Diesel
29
Mar 29, 2014 09:20 AM
55F350Dually
Feb 24, 2005 09:06 AM
95BlackF150
Sep 28, 2003 06:24 PM
