1990 F600 Decode
Hour meter
Odometer
Door tag
N = Class 6--19,502-26,000 lbs GVWR, hydraulic brakes
K64 = F600 diesel, cab model.
P = 6.6L turbocharged diesel, the New Holland/Brazilian engine
9 = Ford use check digit, ignore
L = 1990 model year
V = Kentucky Truck Plant
A48903 = serial number
A1 = If it's a paint code, it's not listed in the MPC I found on line--link below.
129 = 129 inch wheelbase
K64212
K64 = F600
Usually this is 4 characters, like K646 or K647, both F600 diesel with 21,200 lbs GVWR. But yours combines the two for F600, 21,200 lbs GVWR
BA8
BA = Charcoal all vinyl, full width seat
8 = Regular cab
CM = Eaton model FS-6205-B five speed direct transmission (Eaton link below)
G5M
G5 = Rockwell model RS-15-210 two speed rear axle, 15,000 lbs capacity, 4.88 / 6.80 ratios
M = Ford 7,000 lb capacity front axle with power steering
57 = Houston District Sales Office
0284 = Special Order Number
Eaton transmission link:
https://www.eaton.com/content/dam/ea...M0110_0711.pdf
There are some others here who run or have run these engines. Not a powerhouse, and parts will be a hunt, but reasonably well regarded.
Any story on why the low miles?
https://www.dtnaecomponents.com/DTNA...atalogText.pdf
It was done in 1990 so even though info from it might work for later trucks, the key word would be "might".
