Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin decode assistance
Old Sep 22, 2022 | 01:06 PM
Grizzly4x4's Avatar
Grizzly4x4
Good morning,
I have two vins I would like decoded. The first one is my 1990 f700 diesel and second is a 1983 gas f700 at the junkyard with axles I would like to swap but don't know the gearing on either.
Thank You for your time.
Old Sep 22, 2022 | 05:05 PM
85e150's Avatar
85e150
https://cimg5.ibsrv.net/gimg/www.for...da9ef01419.jpg
1FDNK74P1LVA15528
1FD = Ford Motor Co USA, incomplete vehicle
N = Class 6, 19,501 - 26,000 lbs GVWR, hydraulic brakes (Yellow **** on dash for parking brake = expensive Lucas Girling brakes. Great brakes but $$$ to work on.)
K74 = F700 diesel, cab model
P = 6.6 L six in line diesel engine
1 = ignore, Ford use check digit
L = 1990 model year
V = Kentucky Truck Plant
A15528 = serial number
189 = 189 inch wheelbase
YG = Special White
K74245 = F700 diesel, 24,500 lbs GVWR
BK8 = BK = Chestnut all Vinyl-Full Width Seat / 8 = Conventional Cab.
CX = Eaton/Clark model FS-4005-B five speed direct transmission.
W1M
W1 = Rockwell model RS-17-220 two speed rear axle, 17,500 lbs capacity, 4.30 / 6.00 ratios
M = Ford 7,000 lb capacity front axle with power steering
24 = Jacksonville District Sales Office
No special order.
Old Sep 22, 2022 | 05:30 PM
85e150's Avatar
85e150
https://cimg4.ibsrv.net/gimg/www.for...f11cb2bd2c.jpg
1FDNF70H4EVA18624
F70 = F700 gas
H = 370 "Lima" V8. For MY '84, this code covers 2V, 4V & 2V Low compression
4 = ignore, Ford check digit
E = 1984 Model Year
A18624 = serial number
9E = Special White
F700 = F700 gas, 21,200 lbs GVWR
FH8 = Standard cab, I do not have upholstery info
CB = Clark model 282 five speed direct transmission
RDM
RD = Eaton model 16244 two speed rear axle, 17,500 lbs capacity, 6.57 / 9.13 ratios
58 = Twin Cities District Sales Office
No special order.
Old Sep 22, 2022 | 07:07 PM
Grizzly4x4's Avatar
Grizzly4x4
Thank you for your help 85e150. I figured the gasser would be geared higher, too high for my use unfortunately.
fslay
Large Truck
Sep 17, 2022 08:01 PM
Hellboy_32
Large Truck
Jun 29, 2022 06:08 PM
john bogart
Large Truck
Jan 3, 2022 08:32 PM
Hunter Cochcroft
Large Truck
Apr 10, 2020 11:19 PM
ram384
Large Truck
Feb 15, 2020 07:32 AM
