Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Newbie VIN Decode please
Old Jun 29, 2022 | 07:28 AM
Hellboy_32's Avatar
Hellboy_32
1st Gear
Talking Newbie VIN Decode please
Greetings,
I have been a Ford boy since birth all my trucks are blue ovals. I have a F700 I recently bought and I am looking to find out what the Axle code is so I can buy replacement axle seals
Kindly Reguards,
Axle Tag on the Eaton Axle
VIN Tag in the Door
Old Jun 29, 2022 | 06:08 PM
85e150's Avatar
85e150
Welcome to FTE! That's a little hard to read. Let's see what we can read.
1FD = Ford Motor USA, incomplete vehicle
W = Class 6, 19,501-26,000 lbs GVWR, air brakes
K74 = (if that's correct) F700 diesel, "cab model".
N = Detroit model DDA 990N -OR- DDA990T 8.2 liter/501 CID diesel V8
6 = The ninth digit is a Ford use only check digit
D = 1983 model year
V = Kentucky Truck Plant
A46410 = Numerical sequence of assembly.
22 = Rangoon Red
472091
47 = Cincinnati District Sales Office
2091 = Special Order Number. Since engine, trans, axle, color are present, the special order must be for something else.
141 = 141 inch wheelbase
K741 = F700 diesel, 23,100 lbs GVWR
D8 = Standard Cab
CB = Clark model 282 five speed direct transmission
E1M
E1 = Eaton model 16244 two speed rear axle, 17,500 lbs capacity, 5.57/7.75 ratios (Most of the model number is visible in your picture. Clean it with some degreaser and take another pic, you'll probably be able to see the whole label.)
M = Ford 7,000 lb capacity front axle with power steering.
atrovtech
Large Truck
Sep 8, 2021 12:10 PM
Shane269
Sep 6, 2021 10:46 AM
fannin
Large Truck
Feb 11, 2021 12:13 AM
dthut
Mar 7, 2017 09:44 PM
classictruckman
21
Sep 4, 2016 04:35 PM
