C4 transmission linkage
Old Jan 11, 2023 | 09:09 AM
Buddy Seagroves's Avatar
Buddy Seagroves
4th Gear
Hello everyone,
I have a 1969 F100 that originally came with a 360/C6. I've have just installed a early 90's 5.0 roller that's mated up to a C4 from a 66 Fairlane.
The original C6 had the trans shifter linkage oriented downward, which worked as designed with the factory steering column shifter linkage.
I stole a pix off of another C4 post to reflect the original C6 orientation, as well as a pix of a C4 to reflect my current linkage. The problem being
that the steering shaft linkage moves up/down as you shift(pretty obvious I know...), which again worked fine when the trans shifter linkage is on
the downside. However, with my current C4 trans linkage pointing upwards, you essentially have to move the linkage front to back to shift.
So here are my questions/possibilities:
Can you, or is it easy enough to flip the existing upward pointing C4 shifter linkage to a downward orientation?
Is there some pre-engineered trans shifter adapter to change the orientation?
Is there some pre-engineered steering shaft to trans linkage rod that might work, or cable driven solution?
I really don't want to have to tear into the trans pan/valve body(if at all possible) to flip the linkage, nor do I want to put a floor shifter in.
I could probably fabricate a piece of 1/8 steel to bolt up to the existing linkage, to essentially flip the rod mount point, but that's obviously
creating a new point of failure.
Any ideas out there?
Old Jan 11, 2023 | 09:42 AM
351Cleveland C4's Avatar
351Cleveland C4
I'm pretty sure you can flip it over. But you have to Drop the valve body and pull it out from inside.
Old Jan 11, 2023 | 09:59 AM
smoky_diesel's Avatar
smoky_diesel
Build a simple bell crank to reverse direction, add one more rod to trans.
Like this (78 C6 in 72 F250)
Trans has a threaded hole in the perfect spot. Took a bit of testing to find the right ratio to get gears detents to line up correctly.
Old Jan 11, 2023 | 10:27 AM
Buddy Seagroves
4th Gear
Hey smoky_diesel, that was what I thought could be done, I just couldn't see it in my minds eye...
Thanks alot for your reply!!!
Old Jan 11, 2023 | 12:25 PM
smoky_diesel
Your welcome.
The factory did similar on the later Cx trans with upward lever. bell crank bar went from frame to trans or motor.
Mine is bushed with bronze bushing and a bolt shimmed to bottom out on end so it can be properly torqued but not bind up linkage. There is more info in my build thread someplace.
I recently reworked it for the 6R80 trans
Old Jan 12, 2023 | 07:51 PM
JEFFFAFA's Avatar
JEFFFAFA
The difference between up and down linkage is column shift or floor shift.
Jimmy nz
Jan 13, 2023 11:34 AM
jrockdiddy
Jun 28, 2015 09:21 PM
Woodsman_30350
Aug 18, 2008 05:01 PM
mleichtle
Dec 2, 2005 11:47 PM
