Compression check question
Old Jan 10, 2023 | 06:20 PM
78Custom302's Avatar
78Custom302
Last summer I tried to do a compression test, but when I cranked the engine to get a reading, the starter would disengage. Therefore, I was never able to get a consistent reading. Any ideas on what was going on there?
Old Jan 10, 2023 | 06:23 PM
f5fordgirl's Avatar
f5fordgirl
Sounds like a bad Bendix.
Old Jan 10, 2023 | 06:29 PM
78Custom302
I don't have any issues with the starter otherwise--starts fine.
Old Jan 10, 2023 | 06:51 PM
tbear853's Avatar
tbear853
You had all the plugs out and holding the throttle wide open I guess, you maybe holding the gauge ... threaded or push in connection at plug hole.
How were you operating the starter ... button remote starter switch with clamps ... or a helper in the cab ... or what?
If using a clip-on remote starter button, might have been just not clean enough. If using a helper in cab, maybe they let off prematurely ... or maybe the ignition switch or solenoid or Bendix was kicking out.
Old Jan 10, 2023 | 07:02 PM
78Custom302
It was a threaded connection--I don't remember if I was holding the throttle wide open. I might have know to do that. I was engaging the starter from the cab.
Old Jan 10, 2023 | 08:06 PM
Old Guy F-250's Avatar
Old Guy F-250
I am not a mechanic but I have done many many compression checks and can think of no reason for the starter to disengage if everything is operating properly.
Maybe some others may have had that happen and may have an answer.
I would follow Tbears instructions and try it again to see what happens..
Alex
After thinking more about this maybe F5FordGirl may have the answer.
I will try to explain my thinking:::
Maybe the bendix is weak and when cranking with plugs in there is enough resistance to keep the bendix engaged.
then with the plugs out, there is lots less resistance and the teeth will walk off the flywheel???
Just thinking deeper for a reason.
Last edited by Old Guy F-250; Jan 11, 2023 at 09:08 AM. Reason: thinking more about it
Old Jan 14, 2023 | 09:36 AM
78Custom302
That sounds reasonable.
Old Jan 14, 2023 | 09:37 AM
78Custom302
It's the original starter-'78-maybe I should just replace the whole starter(?) What do you think?
Old Jan 16, 2023 | 01:53 AM
Ozzie H.'s Avatar
Ozzie H.
When you say "the starter would disengage", does that mean:
The starter would stop running
OR
The starter would continue running, but the starter drive would not turn the engine.
Old Jan 20, 2023 | 05:30 AM
78Custom302
The latter.
Old Jan 20, 2023 | 09:26 AM
jflem's Avatar
jflem
Sounds like the bendix is bad. I suggest replacing the whole starter.
LegalizeChey
Sep 20, 2022 07:27 AM
papabills54
Jun 25, 2020 04:54 PM
SeaCarr
May 7, 2016 12:45 AM
jdhudall
Apr 22, 2009 12:48 AM
Dieseldan7.3
Jul 13, 2006 11:15 AM
