Help Identifying Broken Wire
Old Jan 8, 2023 | 06:23 PM
jhawkins1029's Avatar
jhawkins1029
4th Gear
Received a new-to-me 1997 F350 7.3L XLT Automatic from my father-in-law and I'm trying to do a once over of the vehicle. Looks like there was squirrels/mice in the engine bay at one point (the vehicle has been sitting up for a long time)
BESIDES a transmission issue (won't shift from 1st to 2nd without momentarily letting off the accelerator and also going straight from 2nd gear into 3rd w/ overdrive, entirely skipping 3rd) - there seems to be some obvious wiring issues.
In the engine bay on what I believe is called the "front under hood harness" there is a completely broken wire going into the connector for the fire-wall pass thru. I cleaned up the wire - but I'm unsure of the color and also not even sure what connector I'm looking at. If anyone can verify the name of the harness or even the plug I'm looking at - I'm pretty sure I can go from there, but at the moment I'm at a loss.
I plan on repairing the wire tomorrow, but I'm not even sure what it goes to to verify my repair?
See photos below.
Overview photo
Remnant of broken wire in the harness
Clearest picture I could get of the color
Ford Part #? listed on the wire wrap
Old Jan 8, 2023 | 10:43 PM
jhawkins1029
4th Gear
Talking
FYI - was able to get a good video of which pin the wire went to and believe I have solved my own question.
It looks like it goes to Pin 1 - shift solenoid #2 (pink/orange wire), which would explain why I'm not able to automatically shift into second and why it skips third... I think...
I will repair the wire tomorrow and report back on if it corrected the shifting and to close out the thread.
Old Jan 9, 2023 | 03:09 AM
DanielT28's Avatar
DanielT28
Let us know how it goes!
Old Jan 9, 2023 | 01:16 PM
jhawkins1029
4th Gear
Talking
Soldered and shrink wrapped a wire splice in the line and what do you know, she automatically shifts for the first time in ~8 years
Old Jan 9, 2023 | 02:13 PM
knottyrope's Avatar
knottyrope
that must have felt good to fix.
Nice job!
Old Jan 9, 2023 | 02:19 PM
Hit Man X's Avatar
Hit Man X
Excellent news.
Reminds me of my 96 not having AC. A pin was slightly recessed on the harness which was a 12V. Right beside a ground...pops fuse every time. Back where it belongs, AC works. Go figure!
How does it drive with all four gears?
Old Jan 9, 2023 | 02:27 PM
jhawkins1029
4th Gear
It's not perfect, but much better than what it was doing before.
Down shifts pretty rough when slowing down (like coming off the interstate to a red light for example), and you can tell it shudders a TINY bit going into 3rd. But the fluid and filter desperately need to be changed, so I'm thinking some of that will clear up or at least get better.
Not sure when it was last changed, but it was overfilled and burnt when I checked it. I drained a quart or so and put some pre-clean in there. Going to drive it a few days then change it. Lurked the forums for the past few days and I'm going to change it using Mark Kovalsky's method with Mobil 1 Synthetic ATF.
MB1776
Oct 19, 2023 05:05 PM
bdwiggin
Aug 28, 2022 04:53 PM
Peritia
Aug 15, 2021 05:46 AM
raptor131
Mar 4, 2017 12:54 PM
