292 cam thrust plate, spacer, eccentric source?
Old Jan 8, 2023 | 06:01 PM
stephen.osborne1's Avatar
stephen.osborne1
My wife and I decided to see if we could make some progress on the 292 that's been on the back burner for a while today. We got to the timing set and realized our cam thrust plate is broken and the eccentric, etc is super rusty. Also seem to be missing a spacer according to the book. Does anyone have an extra set or a source that sells all the parts to install the timing set? (Minus the actual timing gears and chain)
Crusty parts
Broken thrust plate
Need all these except the bolt and washer
Book description
Old Jan 10, 2023 | 01:47 PM
ManFordman2's Avatar
ManFordman2
I have a 239 that is locked up and still fully assembled. I'm sure it has those parts but not sure they are the same as the 292. That book you have has a list of suppliers on the last page which may help. If the 239 parts will work, I could pul them for you.
Old Jan 10, 2023 | 02:09 PM
stephen.osborne1
I'm pretty sure your 239 parts would work. PM me and we can arrange shipping, payment, etc. Thank you.
Old Jan 10, 2023 | 02:13 PM
ManFordman2
Okay. I will pull the parts and then PM. Might take a day or two to get the 239 out of it's hole.
Old Jan 13, 2023 | 08:59 AM
ManFordman2
First look
Old Jan 13, 2023 | 09:06 AM
stephen.osborne1
First look
Doesn't look much better than what I pulled from mine... Let me know if they clean up ok or if you think they're a lost cause. Thanks.
Old Jan 13, 2023 | 10:40 AM
ManFordman2
Sideone and side two
First side
Second side
I think these parts are all useable, just pushing 70 years old. I hit the thrust plate with some 600 paper a little and sandblasted the counter weight. The thrust plate has some wear on the face from the eccentric and the bolts. the other side is quite smooth. The eccentric has a little wear but not too much. The counter weight has some pitting on both sides. Take a look and let me know. I did find a site that might give you an alternative.
https://www.rearcounter.com/C2AZ-626...rts757418.html
Old Jan 13, 2023 | 11:55 AM
stephen.osborne1
First side
Second side
Wow, those cleaned up well! I think they will work. PM me and we can discuss shipping, payment,etc. Thanks again
Old Jan 14, 2023 | 01:42 PM
ManFordman2
Steve,
Let me know if I can help with anything else. Please do keep us posted on your engine progress. Btw, John Mummert has a list of things to be aware of when building a Y block on his website, ford-Y-block.com.
Thanks,
Lester
Old Jan 14, 2023 | 04:20 PM
stephen.osborne1
Steve,
Thanks,
Lester
Will do. Thanks again Lester....
I'll probably continue posting in my build thread "picked up a 64 f100." This project has been on the back burner for a while. Need to get rolling on it when I get home from Belize in a couple weeks. Wifey has been holding the reins on big purchases until after we get back because I've bought 4 vehicles since August... Planning on putting the motor back together and finish welding the floor pans and front cab mounts once I get a better welder. Then it's easy going (relatively speaking) to put it all back together.
stephen.osborne1
Jan 8, 2023 06:02 PM
Chael
Sep 7, 2021 02:01 PM
Rollbar
45
Jan 10, 2020 08:25 AM
67Fordinprogress
Oct 15, 2019 03:03 PM
GaryKip
20
Feb 21, 2016 12:47 AM
