1969 N700 Decode
No title--The estate of the late grandfather will have to provide you with some info and probably a form or two. Which they should have done prior to selling it. Check your DMV for the process of getting a new title upon sale. You might try checking the frame rail on the passenger side about even with the alternator to see if you can find the stamped VIN which should match the one on the door.
I'm moving this to the large truck forum where trucks this size live.
N70 = N700 gas
E = 361 2V FT gas V8
U = Louisville Assembly Plant (didn't they call these the "Louisville Line"?)
E52577 = 1969 numerical series, January 1969 production
163 = 163 inch wheelbase
No color code--color could have been part of the special order.
N704 = N700 gas, 25,500 lbs GVWR, "Except state of PA"
4281 = 42 = Charcoal Black Corinthian Vinyl & Charcoal Black Woven Plastic / 81 = 81A Standard Cab.
M = Clark model 285-V 5 Speed Direct transmission
GHD
GH = Eaton model 17221 Two Speed Rear Axle / 6.50/8.87 / 18,500 lbs. Rear Axle Capacity.
D = Ford Rockwell-Timken 7,000 lbs. Capacity Front Axle.
25500 = 25,500 lbs GVWR
182 3800 = 182 certified net HP @ 3800
380202
38 = Pittsburgh District Sales Office
0202 = Special Order Number. Other than paint, everything else is there, so maybe the special order was just paint.
N70 = N700 gas
GHD
380202
The 17 digit VIN started in 1981, so that link will only work for 1981 and newer.
