Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1972 C750 Decode
Old Oct 7, 2021 | 04:56 PM
usmcpat's Avatar
usmcpat
1972 C750 Decode
Could I ask if you would be kind enough to decode my vin? Also do have any sales history? Thanks for your time
Old Oct 7, 2021 | 05:20 PM
85e150's Avatar
85e150
C75 = C750
F = 391 4V FT gas V8
V = Kentucky Truck Plant
P75286 = 1972 numerical series
135 = 135 inch wheelbase
No color code, note truck is an special order
C755 = C750, 27,500lbs GVWR
118 = Standard cab without sleep compartment
Z = Allison model MT-40 (branded "Transmatic" by Ford) six speed direct automatic transmission
No rear axle code (which would be two digits) Note again this is a special order truck so the color and axle were probably part of that order.
N = Ford-Rockwell (Timken) front axle, 9,000lbs capacity with power steering
27500 = 27,500lbs GVWR
199 3800 = 199 certified net HP @ 3800 RPM
720939
72 = San Jose District Code
0939 = Special Order Number
I have no info on sales numbers. Numberdummy might have had some access to that but he is persuing other interests at this time.
If something doesn't match up, let me know and I will double check.
Old Oct 7, 2021 | 05:28 PM
usmcpat's Avatar
usmcpat
Thanks for your time and willingness to share your knowledge both you and number dummy. Cheers!
Old Oct 10, 2021 | 04:57 PM
Sgt Mustang's Avatar
Sgt Mustang
Wow,
Except for the automatic transmission (which I wish I had), your truck sounds exactly like mine. Mine is a '73 with same wheelbase, engine etc., a former fire truck with just over 20K mile on it. The truck sat for 3 yrs or so before I bought it so as you might expect, there was a few issues to work out. At this time I'm still working on upgrades to the axles and braking issues. I'm curious what your plans are with your truck?
Old Oct 11, 2021 | 05:38 PM
usmcpat's Avatar
usmcpat
Right now the truck is still in its tomb. I got it running and holding air just have to unlock the breaks tomorrow and I’ll give it a try to drive it home. My plan is to leave the drivetrain intact for the most part and soften up the suspension by removing the telephone pole crane and auger bed and removing a few leaves from the spring packs. I’m looking at a set of super singles for the rear and I have a long bed flair/step side bed to put in instead. Little restomod build but I just had a baby so we’ll see how it goes.
Old Oct 13, 2021 | 01:05 AM
Sgt Mustang
I started with mine by dropping it off at a mechanic to begin the transformation about March. The goal was to get it running, stopping and at least movable. I did spend quite a bit of work removing the water tank, truck bed hose reel and fire water pump. Basically stripping it to the frame from the cab back. My goal was/is to update the front and rear axles with modern braking and wheels, improve the drivability and the similar type restomod build. The rear axle + drive shaft was swapped with a 4.3 ratio, dually F350 one and many leafs were removed from the spring pack. The rear axle now sports 22" Alcoa semi truck wheels/tires. After a few other minor issues were taken care of the truck is licensed and drivable. I have a new axle and steering box ready to swap for the front, then I'll get some 22" wheels for the front also. Same plan to remove springs. Last on the list will be modifying the fire truck bed to a flatbed type and re-installing it. Good Luck with your project and congrats on the new baby!
Bruce
USMC
'75-79
Old Oct 13, 2021 | 04:12 PM
usmcpat's Avatar
usmcpat
Thanks and semper fi! Was working on her today and found a bad air brake pot. I’ve got it apart and a new pot but the old gentleman that owns it has a dr appointment on Thursdays, so I’m sunk tell Friday. I tell you what, I was looking at the crane and bed and man that’s going to be a lot of hard work. So when you got rid of all the fire truck nonsense did the truck move out of its way better? The label on the bed said that it’s 25000lbs, I have to imagine that it’s going to be less of a dog. I’m planning on doing an air ride set up and I may back half the frame for smaller frame rails and the ability to get it down in the weeds. I’m going for a crushed pick up look. The engine I want is a cat 3126 but that’s going to be a whole evolution of it’s self.
patrick
usmc
00-08
Old Oct 15, 2021 | 12:08 AM
Sgt Mustang
Patrick,
Without the weight of the hose reel, fire pump, water tank and truck bed, my truck seems to move along quite easily, Since I never drove it with all the equipment I can't really make a comparison though. Swapping the rear end with a different ratio I'm sure made a difference too. My truck had the same GVWR as yours so to ensure I could avoid the the CDL issue, I weighed the truck after removing all the excess equipment and swapping the rear diff and wheels. Then I had it titled at that weight. My truck without fire equipment and swap weighed in at 6850 lbs. My truck does not have air brakes though, just a non working hydravac booster. I do intend on re-installing a modified (lighter) version of the fire bed after the suspension and running gear swap is completed. Airbags may also be in it's future. LOL
Tried to attach a couple pics but no luck.
Good luck with your project. Feel free to contact if I can help answer any questions.
Bruce
Old Oct 15, 2021 | 04:50 PM
usmcpat's Avatar
usmcpat
Hey 85, what are the sales districts?
Old Oct 15, 2021 | 05:11 PM
usmcpat's Avatar
usmcpat
So I have her moving under her own power stoping and starting going forward and reverse. She’s got power steering but it wasn’t working. She’s parked on the side of a hill and there’s a steep slope down and we’re going to wait tell Monday. She’s been backfiring and I crossed the idle mixture screw during the tailgate rebuild and I’m going to tap those threads and see if I can clean that mess up. Found out most of the valves for the crane are super stuck the massive winch seems to engage but the pto cable I can’t get to move. Sprayed pb blaster down it and no luck, any advice on how to unstick old hydro valves are appreciated.
Old Oct 15, 2021 | 08:50 PM
85e150's Avatar
85e150
Ford has districts all over the country as part of it's sale efforts. The dealers order through the districts. Canada has a system of dealers as well.
Being only semi-literate in the art of copying and pasting, I am unable to give you a screen shot at this time.
It's easy to tell what part of the country the truck was originally sold it once you know that code.
Old Oct 16, 2021 | 11:22 PM
Sgt Mustang
no I don't think I can help with any hydraulic issues. When my truck had backfire problems I found the timing was off a bunch. Runs much better at about 10 btdc.
Old Oct 21, 2021 | 08:27 PM
usmcpat's Avatar
usmcpat
Hey Bruce, so I got the truck home and I have a few questions. Is your truck as hungry as mine I burned 2 gallons trying to find the timing marks. So that’s my next question where are they?
Old Oct 22, 2021 | 02:37 PM
usmcpat's Avatar
usmcpat
Found the timing marks buried under the air break compressor.
Old Oct 23, 2021 | 09:01 AM
Sgt Mustang
Patrick, yeah it took me awhile to find them too. Forgot to mention that mine has a holley carb, but once I adjusted the timing, no more sputtering and back firing. All vac lines capped. Spark plugs indicate burning way rich so I been tuning it down some also.
