Transmission clank
Old Dec 27, 2022 | 06:59 AM
Cyawallac's Avatar
Cyawallac
4wd Low
Ok,
I’ve always called that the yoak, I’ve had the drive shaft out several times and lubed the splines with the Motorcraft white Teflon/Lithium grease, not sure what else would be wrong with it, tight fit when it goes back on, thanks
Old Dec 27, 2022 | 07:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by Cyawallac
Ok,
Potato......Spud. Yes, that's it.
I guess you can eliminate a dry slip joint.
Cyawallac
Dec 27, 2022 04:25 PM
Awills
General Automotive Discussion
Mar 23, 2022 12:05 AM
Green Gem
2009 - 2014 F150
26
Oct 24, 2014 08:14 PM
gbiker
6.7L Power Stroke Diesel
18
Oct 15, 2013 10:58 AM
WilliesSD250
Sep 16, 2006 04:33 PM
