Air Starter????
Old Dec 20, 2022 | 03:04 PM
Aaron296's Avatar
Aaron296
Lightbulb Air Starter????
Has anyone ever thought about or actually put an air starter an a 7.3 or 6.9??
Just something I thought about.
Old Dec 20, 2022 | 06:28 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Some diesel locomotives have those. A mechanical engineers terrible idea. If it is used alone and doesn’t have enough air to start the engine you’re stranded. On the other hand if that’s all you have… you don’t have to work that day.
Old Dec 20, 2022 | 07:59 PM
Aaron296's Avatar
Aaron296
I that Mack, International, and Ford had semis with air starters, was just curious to putting one on a pickup as they tend to spin motor faster,
not to mention they sound cool.
Old Dec 20, 2022 | 08:11 PM
85e150's Avatar
85e150
Do you already have a good sized air compressor running off the engine and a couple air tanks?
More weight, more complexity, and if you have an air leak what will you do? No one will be able to jump start your truck, so it will most likely be a tow to home or the shop.
Old Dec 21, 2022 | 12:12 AM
Prototypemech's Avatar
Prototypemech
I've only operated one engine with an air starter. It was an aircraft ground support equipment chiller cart to blow cold air through the fuselage of aircraft while there on the ground.
I can't remember any advantage to them except there's no battery that goes bad every 5 years. Instead, you have to hydrostatic check your air tank every 5 years.... And I had to pump up the tank every time I wanted to use it because it would leak down overnight.
The factory starter and batteries is a really reliable setup.
Old Dec 21, 2022 | 07:18 AM
AuroraGirl's Avatar
AuroraGirl
park on hills and use a manual transmission if you’re are really worried about starters
just make sure it’s enough of a hill so you don’t just compression hold(is that a concern on a diesel?)
Old Dec 22, 2022 | 07:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have run many many air start trucks. and i do not miss them.
are they fun to scare the crap out of people? YUP.
are they fun to have with air leaks that ALL TRUCKS have??? HELL NO!!
Old Dec 24, 2022 | 02:26 PM
CorvusCorax's Avatar
CorvusCorax
6th Gear
How many of us are running around with annoying to find vacuum leaks? Air is the same thing in the reverse direction.
Old Dec 24, 2022 | 02:39 PM
tjc transport
i ain't rite
rite. but an engine will still run with a vacuum leak. air starters will not work with air leaks.
tjc transport
15
Nov 30, 2018 08:56 AM
dwalphinVT
Mar 4, 2017 12:01 PM
Jo Diesel
Large Truck
Mar 30, 2016 04:50 AM
royzell
Mar 25, 2008 11:25 PM
wbhinton
29
Apr 29, 2006 06:44 PM
