E4OD starting off in 2nd gear
Old Apr 22, 2021 | 08:14 AM
King_Kong's Avatar
King_Kong
My 96 f150 (4.9/e4od:OBD2) has been starting off in 2nd gear. Everything else works fine with transmission.
Transmission throws codes P0713 (Trans Temp Sensor) & P1711, even when the trans temp is cold. Not sure if its related to starting off in 2nd gear.
The trans/truck has the following "new" parts:
-new MLPS/TPS/VSS/3rd brake light bulb
-new wiring harness connectors on MLPS & Solenoid Pack.
-Cleaned all the trucks grounds and connectors going from the ECU to the trans with CRC Contact Cleaner
-Did a few complete "battery resets" by taking terminals off of battery & holding them together for 5 minutes.
-Thoroughly went through the entire trans harness, connections, & ECU looking for any obvious damage, corrosion or burns. But nothing obvious was found.
-If I put the shifter into "1", the engine labors & the truck doesn't move (it feels like it's trying to start off in 3rd or 4th).
-If I put it in "2", it feels like 2nd.
-If I put it in "D", it uses 2,3 & 4 like normal. But never shifts fully down to 1st, even when at a complete stop.
-If I put it in "R", reverse works fine.
-Solenoid pack was replaced about 2,000 miles ago with a used one to cure a delayed engagement issue.
Any help on how to diagnose why its starting in 2nd gear would be appreciated. Thanks.
Old Apr 27, 2021 | 05:22 AM
King_Kong's Avatar
King_Kong
Is it possible an accumulator spring failed somehow & isn't allowing the trans to shift into 1st gear?
Old Apr 27, 2021 | 04:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Not an accumulator spring, but the 1-2 shift valve could be stuck.
Old Apr 28, 2021 | 06:45 AM
King_Kong's Avatar
King_Kong
Thanks.
Is that a common problem on 1996 e4od? If so, is it because of bore issues or debris? I'm asking because I want to make sure I can get locally any special parts or tools I might need when I pull the accumulator body off.
Old Apr 28, 2021 | 06:50 AM
Mark Kovalsky
After you pull the accumulator body off, you should put it back on. The 1-2 shift valve is in the valve body, not the accumulator body.
I don't know that it is a common issue.
Old Apr 28, 2021 | 06:55 AM
King_Kong's Avatar
King_Kong
lol. Thanks.
I will try to pull the valve body off on Friday.
Old Dec 24, 2022 | 04:10 PM
F100gt40p's Avatar
F100gt40p
4th Gear
Did you ever figure out the problem?
My 95 E4OD is doing the same thing.
Thanks.
King_Kong
Apr 14, 2021 04:55 PM
Harry-the-hat
24
Feb 22, 2020 05:55 PM
BS51993
Jan 19, 2019 10:43 AM
FORD MEGA CAB!!!
Jul 6, 2012 08:40 PM
randomhero1172
19
Dec 23, 2008 04:46 PM
