352 Performance Upgrade?
He wants to build the engine to 400 HP and lots of torque. I suggested a stroker kit, however could use opinions on what would be a good one. Same with the cam.
It came with w 2 barrel, I can provide him one of my spare 4 barrel manifolds, unless there are better suggestions? Use the original heads?
I have mostly worked with 427's, so this is a bit of a new one to me.
Parts availability is whacky these days. You'll be able to get the straight answers at some place like fepower.net. Cam cores actually are available from Bullet and Comp but that may change. Ask about cam specs at fepower.net...some of those guys love to talk cams and can get you dialed in based on your goals.
Depending on parts availability over 1 hp and over 1.2 lbft per cube should be easily obtainable with the right parts...depending on the budget...and have a streetable engine running on pump gas.
My opinion is to only remove enough metal to make the bores true and get custom sized pistons. Besides saving metal, you can dial in the compression for what ever heads and stroke you choose and get a more modern ring pack for better sealing and reduced friction.
The first thing to do is mic the bores to see what size they are. Who knows maybe it was rebuilt not very many miles ago and bored to an oversize at that time.
Brent Lykins’ 531 Horsepower Naturally Aspirated 352 Ford FE Engine (enginelabs.com)
Performance Summary:
Cubic Inches: 359 Dyno brand: Stuska
Power Adder: Where dynoed: Dale Meers Racing Engines, Buffalo, KY
Peak Horsepower: 512 @ 7000
Peak Torque: 445 @ 5800
Engine Specifications:
Block brand, material, finished bore size, other notes: Factory C6ME-A, 4.040"
Crankshaft brand, cast or forged, stroke, journal size: FoMoCo cast 352 crankshaft, .020"/.020"
Connecting Rods brand, material, center to center distance, end sizes, bolts: Molnar Ford FE 6.490"
Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Racetec 4032, 1.920" compression height, flat top, 10.2:1
Main Bearings, Rod Bearings, Cam Bearings brand and size: Calico coated King main bearings, Calico coated King rod bearings, Durabond FP-33 cam bearings
Piston rings brand, size, other notes: Mahle 4.040", 1mm/1mm/2mm
Oil Pump, pickup, and drive: Melling M57HV, custom pickup, ARP drive
Oil pan, windage tray, oil filter adapter: Custom 7 quart pan with oil control gates
Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"): Custom Lykins Motorsports solid roller, 256/266 @ .050", 106 LSA, .650"/.670" lift at valve
Lifters brand, type: Comp Cams Endure-X
Timing chain and timing cover: FE Power adjustable timing set and factory timing cover
Cylinder heads brand, material, port and chamber information: C6AE-R, JDC Ported
Flow bench used, location: Not flowed
Intake valve brand, head size, stem size: Custom 2.080", 5/16" stem stainless
Exhaust valve brand, head size, stem size: Custom 1.600", 5/16" stem stainless
Valve springs brand, part number, specs: PAC small diameter dual spring
Retainers and locks brand, part number, specs: Manley titanium retainers, Manley locks, Victory lash caps
Rocker arm brand, type (adjustable or non-adj), material, ratio: Modified T&D Street, 1.76:1
Rocker shafts and stands, brand, material: T&D
Pushrods brand, type, length: Trend, 3/8" .135"
Valve covers, brand, type: Chrome PBF
Distributor brand, advance curve information: Factory Ford, locked out, Pertronix conversion
Harmonic balancer brand: Powerbond
Water pump brand, type (mechanical or electric): New cast iron replacement
Intake manifold brand, material, porting information: Ported FE Power adapter, ported Weiand 351C Tunnel Ram
Carburetor(s) brand, type: (2) Holley 660's
