I'm gonna buy a 1965 Ford Galaxie with a 352 engine in a few days and had a couple questions. I would like to know if the 352 is a good engine or would I be better off replacing it with another engine, also is there any performance parts available for the 352. Thanks.
There is a multitude of things you could do with it. It can be upgraded to a 390 or 410. There's a multitude of cams, heads, pretty much anything you'd ever possibly want. Go for it, it's a great engine to have. I wouldn't dream of replacing it.
Thats great news, but what kinda power does the 352 make stock and what kinda power can she make with $1000-1500. Im not trying to make a drag car, just want alittle so she moves decent. Thanks.
Just bore the 352 block .050 over and have a 390 and then use the 390 crank, rods and pistons. Otherwise you are looking at custom piston to get you 380 CID motor. Cheaper to do the 390 thing.
LOL.. well I was assuming a bore to 4.050" because I have seen any standard bore 352's running around My neighborhood in years.. I just figure when mentioning the crank..the rest was a given..
I sometimes forget that not everyone is as up on there FE's as you fellers!!! LOL..
Go for it. Years ago, we had a '64 Country Sedan w/ a 352. It would take the Cascade Mountains in Oregon with ease. There are a LOT of options and MOST of them are power related. If you're looking for a "sleeper" muscle car, you'll have it.
I think the 1960 high performance 352 had a factory rating of 360 hp, so they can do pretty well. I'm guessing you could match that by bumping up the compression, adding headers, a 4v, and a mild cam. I don't know for sure, I'm only answering because I have a similar question. I'm working on my '61 Starliner with a 352 and am weighing my mechanical options. Hoping to be corrected if I'm wrong.
