2000-2001 cab swap
Old Dec 9, 2022 | 07:13 AM
Erikmustang's Avatar
Erikmustang
3rd Gear
2000-2001 cab swap
I love my 2001 F350 Diesel Dually but it has suffered the illness of the Northeast. The cab and bed have rusted to the point where they need to be replaced. I have found a good cab and bed from a 2000 2-wheel drive and would like to install it on my 2001 four-wheel drive. Can anybody tell me if I will have any difficulties doing this? Basically, I'm wondering if there are any wiring problems going from two-wheel drive to four-wheel drive. Also wondering what to do about the VIN number.
Old Dec 9, 2022 | 08:17 AM
Dan V's Avatar
Dan V
You're going to need to transfer all of the wiring to the new cab, if the new cab isn't diesel. (really, transferring the wiring isn't that big of deal, just do it.) If the new cab isn't a diesel, you aare going to need a bit of the firewall where the PCM fits through.
In MN the VIN goes wit the cab, so here that would mean getting it titled as a reconstructed vehicle.
Old Dec 9, 2022 | 08:20 AM
CousinCarl's Avatar
CousinCarl
@runningman777 has done a cab swap and may be able to clarify here.
EDIT: or Dan V
Old Dec 9, 2022 | 08:52 AM
Erikmustang
3rd Gear
Can to cab
The donor cab is a diesel. 7.3 of course. My only real issue is 2WD to my 4WD.
Old Dec 9, 2022 | 09:55 AM
Kwikkordead's Avatar
Kwikkordead
You're not worried about the frame at all?
Old Dec 9, 2022 | 10:15 AM
Erikmustang
3rd Gear
My frame is good I've been taking care of it and then I did the fluid film which made a beautiful difference on the frame
Old Dec 9, 2022 | 10:27 AM
z31freakify's Avatar
z31freakify
Is the 2wd truck complete? And does it have a title? If it does it would be wise to just swap in your suspension stuff to the new chassis, and then do the wiring/power train swap.
Old Dec 9, 2022 | 11:02 AM
Dan V's Avatar
Dan V
I'm thinking the GEM is going to be different. Other than that...and different trim levels....should be plug and play.
SLUF681
Large Truck
Sep 11, 2019 02:53 PM
whitenight2
Jul 31, 2012 06:55 AM
bullrider100808
Apr 25, 2011 04:00 PM
79Supercab400
Mar 27, 2008 07:56 PM
wrecker1975
Feb 1, 2006 07:59 PM
