1968 cab swap
Old Jan 31, 2006 | 09:13 PM
wrecker1975's Avatar
wrecker1975
1968 cab swap
I have a 1968 ford f-350 with a tow truck bed on it
The cab and all the front sheet metal is totally rusted out. I found a nice 76 parts truck with no rust. I have heard that 73-79 cabs will bolt in place of 67-72 cabs. But I have read many conflicting stories on this site. I know that i would have to use the 76 front clip as well, anyone here done this swap or know if it will or wil not work? What kind of fabrication will be necessary if any?? I have heard that 73-79 cabs are about 4 inches longer, and I have heard that 67-72 wheelbases are 4 inches shorter? which is the truth? I cannot have the cab hitting the bed, because I don't have a whole lot of room between the cab and the wrecker bed, nor do I have the room to move the box back 4 inches? I don't know what do do, and I don't want to take it apart and not be able to put the cab on, nor do I want to waste the money buying the parts truck if i cannot use the cab and clip.
Old Feb 1, 2006 | 07:59 PM
4xcrazy's Avatar
4xcrazy
i swapped a 68 cab to a 75 4x4 frame cabs bolted up the same in same boltholes. the difference was the 68 bed was shorter than the 75 bed . front clip was a direct swap also, hope this helps
havi
Aug 19, 2010 04:35 PM
wreckhaul
32
Jan 11, 2007 09:35 PM
tiredone
Aug 12, 2006 04:17 PM
wrecker1975
Oct 14, 2005 05:27 PM
dablack
Oct 15, 2004 01:20 PM
