99 f450 auto trans. We blew out a second flex plate in a few mos. Pulled the trans, flex plate spacer and shim to inspect. Realized we got a used motor w the short pins for a manual. Took 3-4 mos to get back to it and We welded on nuts on the pins and used slide hammer to remove.
replace pins new flex plate and go to tighten the torque converter bolts and can’t spin the flywheel. Put strong arm on the front of motor can’t budge it. Put starter in it and tink. Won’t budge.
motor was running fine before trans removed. Oil fine no diesel or water/coolant. Coolant level right at the line. Any thoughts appreciated?
I wishfully want to believe you inserted the TC all the way in because if you didn't there's your problem, but at an expense of a broken trans oil pump and damage to the TC and maybe more.
When were lining up the tc to push it thru the flex plate holes, I tried to pry on a tooth to turn it slightly and the pry bar wouldn’t turn it. I shrugged it off bc I was in an awkward position just thought I wasn’t getting a good bite. I think it’s locked up.
I didn’t install the flex plate thinking maybe we forgot the shim or bolted the flex plate pinched something binding it up. Or maybe a failed injector o ring or bad injector and we have hydro lock. I’ve got blocks sitting around been on the floor of our shop years and they still turn. Hard to imagine it’s the rings or anything else major.
Have you pulled the oil pan drain plug to check for signs of water? I would about have to think something has gotten bound also. Just having trouble thinking what it might be. If you're pretty sure the back is right what about the front, belt drive, oil pump, gear train?
Edit: Have you tried forwards and backwards on the balancer bolt?
dip stick looks fine. You’d see signs water there. Coolant level perfect too. I’ll drop the belt off try it again. Never seen an oil pump lockup. Low or high. Even w shavings. Why I keep returning to hydro lock. Ran fine last day - no issues at all. Got it out to job and it wouldn’t start back bc the flex plate cracked. Anything would have to be an unusual coincidence.
If it turned over fine before you pulled the transmission and now it won't, the problem is somewhere in the repair job you just did.
betting he left shim off between shaft and spacer before flywheel and the flywheel bolts touching the block. That shim isn’t much but it’s there for a reason.
I'm having a hard time visualizing what the last post is describing.
For the installation of an automatic, there is no shim between the engine block and the transmission bellhousing; the thick aluminum spacer/starter mount is all that goes there. The small plate that goes between the flexplate bolts and the flexplate isn't necessary to turn anything or even run but it spreads the bolt clamping force more evenly. The flexplate bolts also cannot bottom on the block anywhere as they're blind holes into the crankshaft - not into a flange.
scratch that. You are correct. I looked at the block on the floor and got under the truck and looked. There’s no obstruction between the flywheel and the motor. I cannot imagine how the install of the flywheel has anything to do w the fact we can’t turn the motor. Idk.
pulling passenger valve cover first. Seems remote but nothing makes sense about this.
If it's jammed up in both directions, MOST LIKELY, the problem is in the bell housing somewhere. If you put a breaker bar on the front pulley and you can rotate backwards, but it stops forward, then I would agree that something is up inside the engine. Odds of that are astronomical, IMO, given the recent history of having the transmission out. I still think something is out of spec inside the bell housing.
Also don't you have to rotate the engine around just to be able to bolt the torque converter to the flex plate? What happened during that time and right after that?
Here's an EASY check. You might have one or two nuts on the torque converter at this point....take them off. Can you push the torque converter toward the transmission at all? The torque converter should move backwards 1/8" or so. If it does not move at all with the nuts removed, there's your problem.
Hydrolocks USUALLY allow crank movement in the opposite direction at least a little bit and they usually clear up after a few days to a week as the offending liquid will eventually get past the rings and into the crankcase.
