Rolling Engine Cradle
Old Dec 2, 2022 | 03:51 PM
Markus Luukko's Avatar
Markus Luukko
Hey everyone,
Wanted to share a cheap solution to get a rolling engine cradle. Really nice to store your spare engines on.
You’ll need the following
1 2 x12 minimum 64” long
1 2 x 4 minimum 30” long
2 furniture dollys, the small ones from harbor freight or Home Depot
Box of wood screws
Cut the 2 x 12 into 2 32” long pieces
Cut the 2 x 4 into 3 pieces approximately 9.25” wide
The 2 x 12s will go along the engine from front to back and the 2 x 4s will be the cross members, one in the back, one in the front and one under the shallower section of the oil pan.
You will also need to clearance the driver side 2 x 12 for the oil filter adapter.
I turned the 2 x 4 under the oil pan 90* to help support the engine weight.
The dollys roll fine under the weight of the engine.
Old Dec 2, 2022 | 08:10 PM
pvdiag's Avatar
pvdiag
Originally Posted by Markus Luukko
Hey everyone,
I like the doubling up of those simple furniture dollies. I'm going to use that idea for a non engine related project.
Old Dec 3, 2022 | 06:15 AM
FordTruckNoob's Avatar
FordTruckNoob
First, I need a spare engine.😢
Old Dec 3, 2022 | 07:00 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Well done Markus! That will make it much easier to move from here, to there, back to here.
Correction... First you need a bigger garage, then a rolling engine cradle, then a spare engine... Although, that might make your built engine jealous and cause some "friction" among them.
Old Dec 3, 2022 | 07:03 AM
FordTruckNoob
Oh you can bet the spare engine will be even more builterer.
351Cleveland C4
13
Nov 28, 2016 08:03 AM
Hakkamike
Feb 28, 2014 10:26 PM
DeeV8er
Dec 28, 2013 08:42 AM
TheTowingCowboy
24
Feb 1, 2011 05:41 PM
fred_79f250
General Automotive Discussion
13
Jun 1, 2006 08:37 AM
