11 digit vin
N60CUB00521
163. U. N600. 481. A. F7
19500. 1. 64. 3800. 34
That's what's on tag.
Any help would be great.
N60 = N600 gas
C = 330 2V MD FT gas V8. MD for Medium Duty, which in your model years means this engine had the same crank as a 352--cast iron instead of steel. I has the smaller crank snout and the smaller oil pump drive, both the same as the FE engines.
U = Louisville Truck Plant
BB00521 = 1967 numerical series, March 1967 production
163 = 163 inch wheelbase
U = Medium Green
N600 = N600 gas, 19,500 lbs GVWR
481 = 4 = Medium Beige Crush Vinyl & Medium Beige Bar Pattern Vinyl / 81 = 81A Standard Cab
A = New Process model 435 four speed transmission
F7 = Eaton model 13802 Two Speed Rear Axle / ratios 5.83/8.11 / 15,000 lbs. Rear Axle Capacity
No front axle code. In '64-'69 only optional axles were listed. Thus you have the standard Ford axle of 4,500 to 5000 lbs capacity, given your GVWR and rear axle rating.
19500 = 19,500 lbs GVWR
164 3800 = 164 certified net HP @ 3800 RPM, the numbers for the 330.
34 = Indianapolis District Sales Office. This truck was not a special order.
Your front wheels have the split locking ring design. While you may have to search for a truck tire shop to work on those, they are "safe" and not the "widow maker" type. Check you rear wheels for the split locking rings which will be facing each other inside the duals.
Looks like it's a runner in decent shape!
N60 = N600 gas
U = Medium Green
No front axle code. In '64-'69 only optional axles were listed. Thus you have the standard Ford axle of 4.500 to 5000 lbs capacity, given your GVWR and rear axle rating.
Can you please explain this split locking ring?
NEVER MIND!! I got it.
