1993 351w accessory bracket hardware (Lightning)
Old Nov 17, 2022 | 10:01 AM
JamesJ4's Avatar
JamesJ4
long shot on this. I'm rebuilding my 1993 lightning and after a year+ waiting on all the parts I'm missing stuff. Big concern is the missing or rusted bolts/studs for the accessory brackets(p/s and ac bracket and the smog/alt bracket) that bolt to the heads/block. I'm digging deep but have had zero luck. does anyone know if they sell a kit or where i can find any details like bolt size or drawings of this motor so i can buy/order bolts? LMR only has kits for 5.0 mustangs, LMC has nothing and summit has kits for hardware i do not need (plus its luck of the draw speaking with tech help, some help some push you along quick).
Im down to these few bolts to atttach the brackets so i can try to drop my engine and trans in this week to finally get my lightning very close to running after years of waiting.
Old Nov 17, 2022 | 11:08 AM
Scndsin's Avatar
Scndsin
I've got the front of my 94-5.8 down for some work & have been documenting the hardware.
The front dress is pretty standard & will pass along what I record & you can compare.
Old Nov 17, 2022 | 12:10 PM
Scndsin's Avatar
Scndsin
Note that these are all flange head bolts. If you go with std head bolts, washers & lock washers are going to be needed.
Old Nov 17, 2022 | 12:38 PM
groundrat's Avatar
groundrat
They are 7/16-14 bolts. Mine measure 6 inches total length with 5.5 inches from the end of the threads to the bottom of the head of the bolt.
Old Nov 21, 2022 | 12:59 PM
JamesJ4's Avatar
JamesJ4
you saved my life with these pictures. i was able to go back through the pile of bolts that came from my engine builder and find 90%. i had bagged bolts out of order and wrote the wrong info. I appreciate this info and pictures!
Old Nov 21, 2022 | 01:32 PM
Scndsin's Avatar
Scndsin
Glad to help. I know what its like lose stuff & forget what goes where.
Old Nov 23, 2022 | 05:19 PM
AuroraGirl's Avatar
AuroraGirl
I would hold off the lock washer and use thread locker. you dont want there to be any twist on those brackets or your belt drife it just asking for.. yikes
Old Nov 23, 2022 | 05:53 PM
Scndsin's Avatar
Scndsin
I've used a split on top of a flat washer for years when I had no flange style readily to replace lost hardware.
YRMV
Old Nov 24, 2022 | 05:46 AM
2dwoods's Avatar
2dwoods
I've bought a kit at the local parts store in help section I believe dorman is the make
Old Nov 24, 2022 | 02:56 PM
AuroraGirl's Avatar
AuroraGirl
YRMV
I misunderstood haha, i thought you meant a regular bolt with just a lock washer. whoops
Cobydufour
Nov 1, 2022 12:41 PM
tdmoparguy
Aug 4, 2020 12:27 PM
The Peddler
Sep 5, 2014 07:27 PM
Wyokaboy
Dec 15, 2007 10:59 PM
siphor84
Oct 19, 2003 12:30 PM
