Engine questions on 351m/400 engine
Old Nov 13, 2022 | 10:10 AM
PappyPookie's Avatar
PappyPookie
1st Gear
Was replacing heater hose on heater core the one on engine block broke off how to fix or does anyone know part #
Old Nov 13, 2022 | 10:22 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Chisel, hammer, and pipe tap.
Chisel out the pieces of old fitting without bunging up the threads too bad. Then send an appropriately-sized tap in the hole. Use some sealant and install a new fitting.
Old Nov 13, 2022 | 10:23 AM
1TonBasecamp's Avatar
1TonBasecamp
Common problem that I’m surprise isn’t discussed here more often. The original ones just rust fairly early in life, or totally turned to dust where they enter the block.
Mine was starting to deteriorate when it was less than 10 years old.
I’m trying to remember where I bought one, but I hadn’t ever seen them for sale at the local parts stores like you could buy every day for a Chevy.
Oddly enough I think I got mine at the dealer. But I did get one, so that’s the good news. It was 20 years ago though, so that’s the bad news.
I’ll see if I can find the source.
But now that I think about it, it might’ve come from a local engine rebuilder shop.
If you have any of those left in your area you might ask if they have one.
Or just check on Summit or jags first.
good luck!
Old Nov 13, 2022 | 10:38 AM
redroad's Avatar
redroad
Rigid makes a pipe nipple extractor that works real well if that's your problem?
https://www.ridgid.com/us/en/pipe-extractors
Old Nov 13, 2022 | 10:52 AM
tbear853's Avatar
tbear853
I once used a long skinny awl and inserted it between the block and remains of the old pipe nipple, drove it in to created a reverse curve in the nipple which loosened it, pulled it out. Pop new one from NAPA in.
Running just water in the cooling system kills them.
Nice to have.
Old Nov 13, 2022 | 02:53 PM
5851a's Avatar
5851a
Just pressed in like water pump fitting. Use the punch and pliers. Any auto supply store should have a 4-season catalog. Last couple water pumps I bought came with 2 press in fittings in the box, one for 3/4 hose and other for 5/8 hose. Clean the block hole with round wire brush a little gasket shellac on fitting tap in and your good to go.
Old Nov 13, 2022 | 03:17 PM
Mark8man's Avatar
Mark8man
NAPA BK 6601579
Old Nov 13, 2022 | 04:17 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Well no crap. Don't listen to my advice!
Old Nov 13, 2022 | 04:31 PM
redroad's Avatar
redroad
Your advice:
"Chisel out the pieces of old fitting without bunging up the threads too bad. Then send an appropriately-sized tap in the hole."
The point is there are no threads ! You can't be right all the time Cletus.
Old Nov 14, 2022 | 07:56 AM
aldridgec's Avatar
aldridgec
Your advice:
unless you run across one like i fixed where I threaded it and put in a pipe nipple!
Old Nov 14, 2022 | 10:05 AM
redroad's Avatar
redroad
That is how I would fix it too if I had the intake off
Old Nov 14, 2022 | 11:18 AM
black & blue 78/9's Avatar
black & blue 78/9
Last year 2021 I bought one at Car Quest. On the shelf stock.
GTT78
WTB - Parts & other
Nov 30, 2015 08:55 AM
sanders92
1978 - 1996 Big Bronco
Sep 17, 2012 04:34 AM
Jermafenser
13
May 9, 2009 10:01 PM
53fatfndr
Jun 22, 2004 12:21 PM
