Identify this engine? Pic provided.
Old Mar 6, 2009 | 03:46 PM
Jermafenser's Avatar
Jermafenser
I am working on a 1978 F150 that originally had a VIN "H" 351M. I suspect the original engine is long gone.
The engine in there is a 351M/400, although I'm not sure where it came from? It's been painted orange...talk about betrayal.
Here's a pic for anyone that may identify this. While I know valve covers are easily swapped, I want to get at least a clue.
Thanks.
Old Mar 6, 2009 | 07:05 PM
mark a.'s Avatar
mark a.
The sticker says it's a 400.
Old Mar 6, 2009 | 09:17 PM
benshere's Avatar
benshere
Be careful about the orange, Ford has an orange engine paint as well as chebby. I used it when I freshened up my Volvo engine in my boat (its a chebby 350). I did that as a "gottcha" couldnt wait to point it out to one of my buddies . Mark A. is right, although someone could have put the covers on a 351C/351M/400.
Old Mar 7, 2009 | 08:39 AM
Jermafenser
Obviously.
What I want to know what it came out of.
Old Mar 7, 2009 | 08:59 AM
benshere's Avatar
benshere
Obviously, he thought you had missed the obvious. Obviously he was attempting to point out what was obvious, that you may have inadvertently overlooked. It is now obvious that you had, indeed, not missed the obvious. I would obviously expect that mark may regret misjudging you. Isnt that obvious? LOL
Old Mar 7, 2009 | 01:09 PM
Jermafenser
Funny...wisecracker.
Old Mar 7, 2009 | 02:51 PM
85e150's Avatar
85e150
D7AE on the sticker is the only other clue I see, 1977 full size car.
Old Mar 7, 2009 | 03:18 PM
benshere's Avatar
benshere
The full size LTD came with the 400, I had one, a 78----obviously----!
Old Mar 8, 2009 | 01:30 PM
grclark351's Avatar
grclark351
non-original valve covers, non-original engine. the only way to know what you have is to drop the oil pan and check the crank cast code on the front counterweight.
as far as what it came out originaly, good luck! the only way i can think of is to 'map' the cam and cross reference it against the info on the Bubba page.
all that can be told for sure without more info is that it's either a 351M or a 400
Old Mar 31, 2009 | 09:45 PM
79F150400M's Avatar
79F150400M
Get yourself a wood dowel that will fit thru the spark plug hole. Put the dowel in the hole and turn the engine by hand and measure how far down the dowel
travels. 4in=400ci. (400's have a 4in stroke) I've seen this method posted before. Don't know how else to check without going thru all the trouble of dropping the pan.
Old Apr 21, 2009 | 08:10 AM
OzFTrucker's Avatar
OzFTrucker
Ford Australia fitted orange valve covers to most 302 Clevelands from relese in 1972 until about 1978 to distinguish them, in the public view, from the previously offered 302 Windsor.Just abit of useless information for anyone who might care.
Old Apr 21, 2009 | 09:00 AM
benshere's Avatar
benshere
Just a quick thought on using the dowel to check stroke, see if it works (I havnt tried it--yet!)
Use #1 cylinder and remove plug. Measure to top of piston, at TDC using a reference point somewhere (top of plug threads, exaust flange top of head, etc ) Remove dowel and rotate 180 deg, maybe use a degree wheel or balancer tape----or maybe pull dist cap and watch rotor for 180. Reinsert dowel at the same angle and measure to same reference point. Lastly, measure length difference (not trying to make anyone look stoopid ). My guess is it would be a little easier than leaving the dowel in while rotating. Whatever works--
Old May 2, 2009 | 01:00 PM
Bill_Beyer's Avatar
Bill_Beyer
Assuming the valve covers have NOT been swapped (big assumption) that engine is a 400 most likely out of a 1977 or later large sedan (LTD, etc.) or it could be out of a 1979 F-series as well since they went to cat conv in 1979.
Old May 9, 2009 | 10:01 PM
havi's Avatar
havi
I'll have the Roast Duck
Read the date code on the block and either head. Should give ya a starting point, no?
