Exploder Intake do-able?
Old Nov 10, 2022 | 01:48 PM
1ole4d's Avatar
1ole4d
As I've have been cleaning up this 302 from the '96 Explorer I started wondering if it's possible to use the upper and lower intakes in the truck. Obviously, the air intake would need to be modified a little and since the air pump equipment would be eliminated that would free up the space on the right fender. The throttle and cruise control cables would need a custom bracket I'm sure. Other than that, would it be feasible to use the Explorer intake or is it just better to swap the truck intakes over and be done with it?
Old Nov 10, 2022 | 02:22 PM
R&RFord's Avatar
R&RFord
The stock truck 302 intake is a good piece as is. I don't think you will find any performance advantage swapping to the explorer version, which should be a cast version of the GT40 intake. The explorer intake isn't bad just not better and not worth the trouble.
Old Nov 10, 2022 | 04:42 PM
Hit Man X's Avatar
Hit Man X
Agreed, not worth hassle.
I would hope you would swap in spicier camshaft while the other long block is out. Unless you have, disregard
Old Nov 10, 2022 | 07:47 PM
Mudsport96's Avatar
Mudsport96
X3. It would be okay in a lighter vehicle. But the long runners help the low torque 302 get these trucks moving. Stick with the truck intake, you will be happier.
Old Nov 11, 2022 | 07:45 AM
1ole4d's Avatar
1ole4d
I had debated on doing that but I don't think I will. This is supposed to be just a drop in and go deal. The newer 302 is rated about 30 more hp than the hamster wheel that's in there now so I'm sure it'll be fine. If I'm going to spend the extra money on internals I would much rather do it on a 351w. Then again, I am a sucker for more power and noise...
Old Nov 11, 2022 | 08:44 AM
Conanski's Avatar
Conanski
Ther Explorer/GT40 intake is still considered to be a long runner version and there isn't enough of a difference in runner length between it and the truck intake to make a noticable difference. Plus both of these intakes are much larger in terms of airflow capacity than a stock 5.0 needs so it's a bunch of work for no gain on a stock motor, if you really want an intake that will maximize torque go find a 5.0HO version.
Old Nov 11, 2022 | 05:07 PM
Hit Man X's Avatar
Hit Man X
Well, at least do some decent valve springs, stem seals, and new timing set.
HO cam works well and is cheap. Runs on speed density fine too. Not the best but better than stock with a decent torque curve.
Old Nov 11, 2022 | 06:58 PM
R&RFord's Avatar
R&RFord
If the OP is using the 96 explorer engine it should have the F4TE roller cam in it, which is a good torque roller cam as is.
FordYoungGun35
Sep 18, 2012 08:57 PM
ChristopherN
Apr 20, 2011 10:51 PM
Jrock909
Feb 22, 2007 04:08 PM
Jrock909
Jan 3, 2007 10:28 AM
