Fluid change question
Old 11-06-2022, 08:06 AM
Smgchandler's Avatar
Smgchandler
Smgchandler is offline
8th Gear
I’m replacing clutch in 1989 f250 with 5 speed and 5.8 engine. I would like to change fluid in transmission and transfer case and my question is ( with the newer synthetics out there) what should i put back in the transfer case and transmission ?? Thanks
Old 11-07-2022, 08:27 AM
jas88's Avatar
jas88
jas88 is online now
Regular ATF IMO.
Old 11-07-2022, 09:01 AM
Smgchandler
8th Gear
I appreciate that - I’ve read and read until tired of reading !! When you say reg atf - can you specify ? I know some is hard to find mercon this and that and F and others that meet specs. I would like to have it when i take for a clutch change next week. Thanks
Old 11-07-2022, 10:48 AM
Hit Man X's Avatar
Hit Man X
Hit Man X is offline
Received 1,240 Likes on 1,011 Posts
Redline D4 for the trans is what I use. I ran it on a 500mi break in on that 'Universal ATF' from Autozone, worked fine. It is supposedly to take the place of Mercon/Dexron but who knows its exact formulation.
Unsure what the transfer case specs, cannot help you there.
Old 11-07-2022, 12:48 PM
jas88's Avatar
jas88
jas88 is online now
Just go to Walmart and get the stuff marked "ATF".
th67ss
10-23-2010 08:51 PM
02GrayPowerStroke
08-02-2010 05:13 PM
98 4.6 locked up
1997 - 2003 F150
07-25-2004 10:22 AM
Quick Reply: Fluid change question
