Torque convertor
Old Oct 21, 2022 | 07:50 PM
Randy777's Avatar
Randy777
Torque convertor
I have a 2004 Ford F250 shortbed with the 6.O. Doing an automatic transmission fluid change. Truck has 102,000 miles on it. My question is their any way to change the fluid in the torque convertor too. Cannot find any drain plug or any youtube videos on changing the fluid. Thanks ahead for any help
Old Oct 21, 2022 | 08:23 PM
TooManyToys.'s Avatar
TooManyToys.
This guy was the first to do it this way.
Old Oct 21, 2022 | 09:32 PM
Randy777's Avatar
Randy777
Thanks so much for this video. I will start this project tomorrow. Again, Thanks for the help
Old Oct 22, 2022 | 07:42 AM
bismic's Avatar
bismic
The flush above is definitely better, but you can just do a series of drains and fills with some driving in between to completely mix the new fluid with the old. It is a fair cost due to all the fluids, but it is easy.
2 drains/fills changes 70% of the fluid.
3 changes about 83% of it
4 changes about 91% of it.
I have 240k miles on mine doing the drains/fills.
Old Oct 23, 2022 | 09:57 AM
joe blow's Avatar
joe blow
How about taking it to a dealer where they use the hot flush machine (if you have not converted over to the '08) pan and filter?
Seems like the cost of oil cases and labor doesn't outweigh the price of convenience on this one.
But it may only hold true if it is the screen type filter.
Old Oct 23, 2022 | 10:33 AM
TooManyToys.
My old memory seems to think Mark K saying it doesn't work so well on the 5R100w, not that I'm sure it does on any.
With our MDX, I do 3 drain and fills right after each other. That is how Honda/Accura says to do it in the service manual and how they do it at dealerships. But that's 3qts at a time.
When I was taking care of my granddaughters Escape, the forums came up with a way to disconnect the trans line and do a full fill & flush, in some respects not so different than the video. I think that process is here in this forum, Escape chapter, under my old handle.
Old Oct 23, 2022 | 11:36 AM
bismic's Avatar
bismic
Yeah - the "hot flush machine" is a myth as far as I am concerned.
Old Oct 23, 2022 | 11:52 AM
joe blow's Avatar
joe blow
Damn I stand corrected. Here I am living in a fantasy world in my own head (and I ain't leaving)
Old Oct 23, 2022 | 01:17 PM
bismic's Avatar
bismic
I was told that it needed a hot flush, on this and several other forums, but I talked to a dozen dealerships and they said they had never heard of it. To add to that, I have never seen a thread where a person found a shop with one.
Fooled me too for a long time.
Old Oct 23, 2022 | 01:20 PM
joe blow's Avatar
joe blow
I am in good company then
Thanks for dispelling the rumor.
Old Oct 23, 2022 | 01:25 PM
joe blow's Avatar
joe blow
This is the closest I have found, and its sole purpose is to clean out the residual junk that made your tranny fail to begin with, when changing main components ( TC, trans or overhaul of trans). I see how it can be misconstrued as a hot flush service interval.
blue66tang95f150
Nov 20, 2015 10:21 AM
bohiaa
May 10, 2006 08:08 AM
A_Flyfisher
Mar 8, 2004 06:21 PM
QBall
Dec 28, 2003 02:26 AM
greg_23805
Jul 30, 2003 06:31 AM
