Transmission Fluid Change
Old Mar 8, 2004 | 05:07 AM
A_Flyfisher's Avatar
A_Flyfisher
HI!
I have a 2000 F250 PSD w/ auto tranny and 4x4.
At various mileage intervals the factory scheduled maintenance booklet says to change the auto. transmission/transaxle fluid on all vehicles equipped with AX4S, AX4N, 4R70W, 4R100, 4F27E.
What do these references (AX4S, etc.) mean, and does my truck have one or the other of them?
John
Old Mar 8, 2004 | 07:16 AM
mueckster's Avatar
mueckster
These are various models of different transmissions. You have the 4R100. Ford recommends to change the fluid every 30,000 miles of these transmissions. The year model you have should have a drain plug on the torque converter. If you service the trans yourself, you get almost all the fluid out by draining the pan and torque converter. I have been doing the "complete" drain every other fluid change. I service it a little sooner if I do quite a bit of towing.
Old Mar 8, 2004 | 09:01 AM
A_Flyfisher
Thanks for the info. I'm not very knowledgable about mechanical things but I do want to make sure to meet the service interval requirements.
John
Old Mar 8, 2004 | 03:09 PM
johnsdiesel's Avatar
johnsdiesel
Draining the fluid yourself you will get only about 2/3 of the fluid out. I recommend taking it to a shop that can get all the fluid out.
Old Mar 8, 2004 | 06:21 PM
Casey's Avatar
Casey
Or try this do it yourself version of what the transmission shop will do. I've used this method several times. It isn't hard at all.
https://www.ford-trucks.com/articles...hangingatf.php
