Loping,rough idle
Oct 16, 2022 | 04:59 PM
4th Gear
Loping,rough idle
So im new here, but I own a 1996 f350 with a automatic transmission I have changed glow plugs valve cover gaskets and pigtails. I also changed ICP,CPS and IPR. Truck starts up after cranking over a few times then within 5 seconds the CEL comes on and the truck starts to lope not terrible but definitely not normal. Hit the pedal truck runs fine,let off goes back to loping. I also started it and put the truck in neutral and still lopes so assuming it’s not the neutral safety switch.
Oct 16, 2022 | 07:54 PM
Does it have a chip installed?
have you performed a wire continuity test to make sure the new wiring is correct and in good order?
Oct 16, 2022 | 08:13 PM
4th Gear
The truck is completely stock besides a air intake. And I have not done a continuity test
Oct 16, 2022 | 08:40 PM
Lopeing means the PCM is not sure what to do based on HP oil pressure reported
Oct 16, 2022 | 08:44 PM
4th Gear
Is there a way to test the hpop. I have brand new icp and ipr on the truck is there something else I should look at before the hpop
Oct 16, 2022 | 08:59 PM
Its most likely not the HPOP . Get it scanned .
Oct 16, 2022 | 09:00 PM
4th Gear
Will do. Could it be something other than icp and ipr
Oct 17, 2022 | 11:05 AM
Did you accidentally wire the pigtails incorrectly?
Oct 17, 2022 | 03:17 PM
Liquid10Rider
Nov 18, 2019 03:50 PM
flatbed444E
Dec 2, 2014 06:05 PM
jgavac
Feb 3, 2013 07:35 PM
ghunt
Oct 16, 2009 09:39 AM
SBFD8
May 5, 2008 09:22 AM
