Intermittent Glowplugs
Old Oct 17, 2022 | 08:17 AM
CFortney's Avatar
CFortney
1st Gear
Recently I’ve been having issues with my 95 7.3ps. The wait to start light always comes on, but the relay only works if the vehicle is cold, usually first thing in the morning. Any time after that, the light comes on, but I can tell by the battery indicator and the rough start that the relay isn’t actually actuating. I’ve already put a brand new relay in and it isn’t making a difference. I also notice that it’s taking a lot longer to build oil pressure even though it just had an oil change and it’s at the perfect fluid level.
Old Oct 17, 2022 | 11:59 AM
Hit Man X's Avatar
Hit Man X
A warm 7.3 will not need glow plugs to light off, mine does not need them until low 60s on the Fahrenheit scale. You probably have other issues to sort.
Old Oct 17, 2022 | 12:02 PM
knottyrope's Avatar
knottyrope
is the airbox temp sensor plugged in and or working?
its not really needed except for really cold climates
other than that engine oil temp sensor when reading low, GPR will engage
Old Oct 17, 2022 | 01:53 PM
z31freakify's Avatar
z31freakify
If it's hard to start hot could be 4 possible problems, it could either be bad injector O rings letting oil escape, bad injectors, could be a sticky IPR/torn O rings/ bad coil, or the starter isn't spinning to engine fast enough.
Old Oct 17, 2022 | 07:42 PM
Action4478's Avatar
Action4478
Since you were posting about glow plugs , the on time is determined by oil temp. The sensor for the GPS is on the Backside of the high pressure oil pump .The sensor for the dash gauge is on the top (idiot light so to speak) The OT sensor may be faulty or the connection may need attention . BTW , as far as I know we don't have an AIT sensor ( at least my 97 does not ) . Get the truck on a scanner & monitor oil temps warm & cold . GP on times can be read as well .
adam10
Apr 23, 2012 10:41 PM
6.9idiatsturbo
Apr 19, 2012 09:06 AM
dyoungen
Jan 22, 2010 09:14 AM
jiggersup
Sep 15, 2009 07:16 PM
Troy Banning
Jul 27, 2009 10:23 PM
