Hydra Problems
Old Oct 15, 2022 | 05:12 PM
mbauska's Avatar
mbauska
2nd Gear
Hydra Problems
I have the Hydra tuner in my 2002 F250 no problems with it until now. This morning started my truck for work, and put it into a high idle to warm up for a few min. Now I cant get it out of it, any ideas?
Old Oct 15, 2022 | 06:47 PM
RacinJasonWV's Avatar
RacinJasonWV
Maybe controller went bad or came loose?
Does it light up?
Do the numbers change on the controller or is it stuck?
“00” and a key cycle will put it into bypass mode.
You can always pull the chip and revert to stock. Make sure the keys are out of the ignition before moving the chip around.
Old Oct 15, 2022 | 08:13 PM
mbauska's Avatar
mbauska
2nd Gear
Controller lights up its stuck on a number lets say 1 and it won't change from that. I can pull the chip and see what it does.
Old Oct 15, 2022 | 08:59 PM
udsuth78's Avatar
udsuth78
Yep I'd go for the tech support bread and butter fix all. Turn it off, then back on again. In this case, disconnect the batteries for a bit then hook'em back up.
Old Oct 17, 2022 | 01:56 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
X2 on that
268Fords
May 15, 2017 11:40 PM
immastrokinnow
Mar 20, 2007 07:42 AM
pmasley
Aug 13, 2006 09:18 AM
mtgrzlyman
Mar 9, 2006 08:17 PM
dewaltkid
Nov 11, 2005 12:36 AM
