problems with 6 bank chip
Old Oct 27, 2005 | 09:43 PM
dewaltkid's Avatar
dewaltkid
I installed the bullydog 6 bank chip today and did it by instructions and it said "if wait to start light does not come on reclean the outside conections" in the meantime I pulled the chip and tried to start and the wts light came on and it started. So then I cleaned the connections again and tried it samething. But then when I pulled the chip it would not work that way either. Help please
Old Oct 28, 2005 | 02:41 AM
dewaltkid's Avatar
dewaltkid
nobody with even an idea on this?
Old Oct 28, 2005 | 04:51 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Were your keys in the ignition while removing the chip?
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 28, 2005 | 05:03 AM
dewaltkid's Avatar
dewaltkid
I don't remember what would that do?
Old Oct 28, 2005 | 12:37 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
If they were, it powers up the PCM. When you put your keys in the ignition you get electrical current so it is a good chance you might have ruined the chip and or both chip and PCM.
__________________
Old Oct 28, 2005 | 04:18 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Keep at it. Under the grease on the PCM connector is a cear coating.....reminds me of shellac. Occasionally it is neccessary to scrape this coating off with a knife in order for the chip to make contact.
If it started fine after you removed the chip the PCM is undamaged.
Old Oct 28, 2005 | 04:45 PM
SpringerPop's Avatar
SpringerPop
That stuff is called "conformal coating" in the printed-circuit board industry.
It (hopefully) allows the electronics to continue to work when exposed to high-moisture environments.
Pop
Old Oct 29, 2005 | 12:13 AM
cookie88's Avatar
cookie88
FTE Emeritus
Thanks Pop. All I know is it's impossible to get a chip to make contact with the stuff on there.
Old Oct 29, 2005 | 12:25 AM
SpringerPop
And the military-grade stuff is even worse, (if that's possible)!
Pop
Old Nov 11, 2005 | 12:36 AM
dewaltkid's Avatar
dewaltkid
talked to a local diesel tech today and he said that it probally was that I had left the key in the ignition and it send small but destructive signal to the pcm and that is probally what fried mine. Anyway I got a new pcm but it had different code and my truck now works. My old chip I sent back and he said that he tried to reprogram it for my new pcm and it fried his programer. He sent me a new one and hope to install it tomarrow. I wish that bullydog would have that in their instructions. $320=lesson learned.
