Temp sensor connector?
Old Oct 11, 2022 | 12:00 PM
6860media's Avatar
6860media
Trailering
I have this connector for the sensor but I have seen ones that connect directly to sensor. Which one do I need? Also, what does the female connector look like coming from the firewall?
thanks
Old Oct 11, 2022 | 03:02 PM
1TonBasecamp's Avatar
1TonBasecamp
That’s just a universal/generic replacement. Meant to be spliced into the existing wire after you remove the old connector.
As far as I know there is no connector on at least some of our trucks. Just the one at the sending unit and then the wire that runs into the harness.
Some vehicles, like the early bronco did have a connector at the firewall, but it was in a multiplex type, three wire connector sharing duties with the water temperature and oil pressure in ignition coil.
What year and model is your truck?
Old Oct 11, 2022 | 03:25 PM
6860media's Avatar
6860media
Trailering
78 ford f100
Old Oct 11, 2022 | 04:14 PM
1TonBasecamp
Your 78 might just have one of those multi wire connectors similar to a Molex that has removable contacts.
If so then you can make your own from start to finish. Unfortunately I’m not sure if you can buy that full harness or not from any of the reproduction vendors.
It might be out there and I’ve just never seen it.
One thing I found over the years is that the reproduction 90° push on connectors don’t often fit like the original.
They’re either too loose or too tight.
Old Oct 11, 2022 | 08:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 that one is a common replacement that is meant to connect to the lone wire coming out the eng harness bundle. NO separate elec connecter.
Dalton2413
2009 - 2014 F150
Feb 24, 2025 07:58 AM
nomadw8
15
Sep 5, 2019 11:52 AM
ozziesstang89
Aug 2, 2019 12:35 AM
cdiddy
Dec 27, 2006 04:17 PM
smittyranger1993
1983 - 2012 Ranger & B-Series
May 5, 2004 09:39 PM
