Sponsored by: Real Truck
Replacement key without Original?
Old Oct 2, 2022 | 06:22 PM
machgirl03's Avatar
machgirl03
Have a 2012 F250 Super Duty 6.7L. I lost the original key, and did not have a spare. Do I have to have it towed to a Ford Dealer to get new keys made?
Old Oct 2, 2022 | 06:30 PM
projectSHO89's Avatar
projectSHO89
Since you have NO keys at all, your choices are to either have a GOOD mobile locksmith to come out to the truck or tow it to the dealer or a shop that can do the repair.
Not many choices for the DIYer unless you are very capable. You (or the dealer/locksmith) would have to drill out the ignition cylinder, and replace it, along with the door cylinder(s) with new keys cut to the new cylinders and then program the keys into the PATS systems.
Old Oct 2, 2022 | 06:36 PM
machgirl03's Avatar
machgirl03
That's what I figured. All I know is the Ford dealers around where I live want way too much money to replace the keys. Makes me wish I had gotten a spare when I had the chance!
Old Oct 2, 2022 | 08:06 PM
projectSHO89
Yeah, it's going to cost HUNDREDS to resolve (unless you (DIY). Twice as much at the dealer, tho.
Good luck...
Old Oct 2, 2022 | 08:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've had this happen. If the truck is under 10 years old the dealer can make a new key without the truck being in the shop. You need the VIN, a government issued ID, and proof of ownership. They can look up the original key code and cut a key from that.
I had this happen to a car older than 10 years. I had a mobile locksmith come out and cut two new keys. He didn't have to change anything on the car, he just did his magic and made me two keys that work fine in the car. This was about two years ago, it cost $170.
Old Oct 2, 2022 | 08:55 PM
machgirl03's Avatar
machgirl03
Crap lol! My F250 is almost 11 years old now...that sucks. Well, guess it is off to find the best locksmith!
Old Oct 3, 2022 | 06:54 AM
projectSHO89
They can indeed cut new keys for a vehicle that is within the range that they still have the data for. The replacement keys do, of course, still need to programmed for PATS (and RKE functions, if applicable). PATS can be DIY with Forscan. Will still cost over $100 per key with minimum of two needed.
Curious if that was a PATS-equipped Ford? Also curious how he was able to figure out the mechanical key cuts. Does sound like magic if he couldn't take the cylinder apart.
Call your dealer anyway with your VIN. You might get lucky!
Old Oct 3, 2022 | 09:47 AM
Mark Kovalsky
Yes, it is a 2002 Lincoln LS and it has PATS. He looked up something and cut the keys. He then used a scan tool to program them to the car. The car started and ran with those keys.
Old Oct 3, 2022 | 09:49 AM
machgirl03's Avatar
machgirl03
Call your dealer anyway with your VIN. You might get lucky![/QUOTE]
Dealer says they have to have my F250 there to program it...
The key itself runs 170 plus tax plus programming is another 180 plus tax....SHEESH.
Old Oct 3, 2022 | 09:53 AM
Mark Kovalsky
Dealers are often a good choice, but are usually the most expensive choice.
When I lost the keys to my 2002 Lincoln LS with PATS I saw a locksmith making keys on a dealer's lot. I talked to him and made an appointment to come to the house and make two keys, including programming. My total cost was $170. The keys work fine.
Find a local locksmith. They know how to do this.
Old Oct 3, 2022 | 09:56 AM
machgirl03's Avatar
machgirl03
[QUOTE=projectSHO89;20578040]They can indeed cut new keys for a vehicle that is within the range that they still have the data for. The replacement keys do, of course, still need to programmed for PATS (and RKE functions, if applicable). PATS can be DIY with Forscan. Will still cost over $100 per key with minimum of two needed.
What is Forscan? So is what you are saying that I buy 2 keys from the dealer, use this Forscan to DIY the programming? What if the dealer says they won't let me buy keys without programming it there?
Old Oct 3, 2022 | 10:14 AM
Mark Kovalsky
You can download Forscan at www.forscan.org. I recommend calling a locksmith. They can do the whole process for about half of what the dealer will charge you for only the keys, if they will sell you the keys without the programming.
Old Oct 3, 2022 | 10:36 AM
machgirl03's Avatar
machgirl03
Yeah, I did not ask the dealer that I called if they sell the keys without the programming. I wouldn't know at all how to program the truck myself. I mean, I have done quite a bit of auto repair, but electronics is not my forte. Guess I am gonna have to try to find a locksmith who is willing to work on my truck. I have heard from other forums that not too many locksmiths like to work on these trucks' keys due to their complexity? Is that true?
Old Oct 3, 2022 | 10:40 AM
projectSHO89
OK, that makes perfect sense now that you've mentioned that they were programmed after cutting. I wonder if the locksmith had access to Ford's key cutting database. Sounds like it.
Old Oct 3, 2022 | 10:46 AM
machgirl03's Avatar
machgirl03
So 2 different Ford dealers are saying they are not going to be able to do anything with my truck due to the production date being Sept. 14th, 2011. They said they don't have access to the key codes because it's older than 10 years. What am I going to do now?
Will I have to get a whole new ignition lock cylinder???
