Sponsored by: Real Truck
Replacement key without Original?
Old Oct 3, 2022 | 01:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by machgirl03
So 2 different Ford dealers are saying they are not going to be able to do anything with my truck due to the production date being Sept. 14th, 2011. They said they don't have access to the key codes because it's older than 10 years. What am I going to do now?
Will I have to get a whole new ignition lock cylinder???
I should have mentioned this earlier.
CALL A LOCAL LOCKSMITH!!!!!!!!!!!!!!!!!!! THEY CAN CUT NEW KEYS AND PROGRAM THEM FOR YOUR TRUCK FOR ABOUT HALF OF WHAT THE FORD DEALER WILL CHARGE.
I'm done with this thread.
Old Oct 3, 2022 | 02:05 PM
machgirl03's Avatar
machgirl03
Ok, thank you.
Old Oct 3, 2022 | 04:39 PM
EDC8008's Avatar
EDC8008
I have 3 keys for mine 2 with the remotes and one valet without. I programed the valet key myself and it's not that hard. You can find directions on You Tube.
Old Oct 3, 2022 | 07:48 PM
Old and soft's Avatar
Old and soft
Used to work at a lock shop doing commercial door work. It is mind blowing what a good locksmith can do. Good thing they use their gift for good instead of evil.
Old Oct 4, 2022 | 02:54 PM
nydiver's Avatar
nydiver
If you have 2 keys known to the truck, then yes, you can easily program in additional keys. Without a single key available you MUST call a locksmith, they can pick the tumbler and measure the pin depth to determine a cut for the cheap plain jane key, sometimes they make 2 or 3 keys before they get 1 that can turn the tumbler, they then cut a transponder key to that determined cut and using a key programmer they put it in the PATS. Might as well get 2 made while he's there, cheapest that way.
Old Oct 5, 2022 | 05:15 PM
machgirl03's Avatar
machgirl03
The dealer was saying something about a KEY CODE..and that how they dump those files after the vehicle hits 10 years old...does a locksmith have to do anything with these?
Old Oct 5, 2022 | 05:56 PM
Old and soft
I have seen locksmiths make keys for older fords. They started with a key blank and a special file. They insert the key to be made and twist back and forth gently. Then they read the witness marks on the key blank and touch the file to the witness marks they saw. I did not see squat. 2 minutes later they have a key that turns the ingition. They then compared it to a key cut gauge and cut a key by the code they determined. Less than a 10 minute process. This is a talent just like musical instruments.
GIVE UP ON THE DEALER AND CALL A LOCKSMITH. Ask if they can cut it and program it before you have them come out. We used to provide service within a couple of hours of your call.
Old Oct 5, 2022 | 06:07 PM
machgirl03's Avatar
machgirl03
Ok I just wanted to be sure! Will be calling a locksmith! Hopefully find a good one.
norman2012
Nov 13, 2021 07:47 PM
Iraqvet05
Mar 19, 2021 11:44 AM
sne43
Transit Connect
Jul 8, 2019 02:22 PM
daniel262
Dec 26, 2010 09:59 PM
nafzimo
Dec 9, 2002 11:04 PM
