Smoke
Old Sep 22, 2022 | 08:08 PM
74 Blacky's Avatar
74 Blacky
7th Gear
Smoke
I’ve researched old threads but wanted some fresh feedback. My 74 F100 390 FE motor smoked when I let off the gas running 7 years ago when I parked it. I finally got it cranked and bringing it back to life. I don’t have rolling tires on it yet but setting idle it smokes,Not so much when I rev it up. It has a rebuilt short block from Advance auto but I think my father out the old heads on it. It has to be the head seals etc. right? Any chance the smoke is ring related?
Old Sep 22, 2022 | 08:30 PM
1TonBasecamp's Avatar
1TonBasecamp
Presumably it’s smoking out of the exhaust. Correct?
How old is the remanufactured engine, and has it been run before?
Is this the same engine that smoked before?
Are you saying that the cylinder heads have been refurbished, or were the old ones put on the new block?
I’ve been able to get perfectly good engines to smoke out of the exhaust at idle by adjusting ignition timing too far retarded or advanced, but that’s probably a longshot.
Old Sep 22, 2022 | 08:36 PM
440 sixpack's Avatar
440 sixpack
Probably a combination of all things. most likely your guides are loose and your stem seals are shot. possibly in brittle pieces.
The easiest thing would be some smoke stop product and it will help, but maybe not enough. next would be new valve seals they're not that hard to change. if that doesn't do it then pull it and begin the rebuild.
Old Sep 22, 2022 | 08:37 PM
85e150's Avatar
85e150
If it smoked when you let off the gas 7 years ago, it was the valve seals. The neoprene umbrella seals get hot, harden up, and then break into little pieces.
Pull a valve cover and see for certain.
They can be replaced with the heads on the engine IF the heads are otherwise sound. A compression test will give you most of the answer there. The other one is if they will hold water under pressure.
Good luck!
Old Sep 22, 2022 | 08:38 PM
74 Blacky's Avatar
74 Blacky
7th Gear
Smoke out exhaust, same engine as before. I let it go without cranking for years. The short block is 14 years old and not sure what my father done to the heads. I suspect he used the old ones that leads me to believe it’s the culprit.
Old Sep 22, 2022 | 08:46 PM
74 Blacky's Avatar
74 Blacky
7th Gear
Thanks for the info guys. I will do compression test first. Would love to fix this without pulling the heads.
Old Sep 23, 2022 | 06:12 AM
mark a.'s Avatar
mark a.
Are you sure it is oil smoke ? What do the plugs look like ? Maybe it's the carb, that's a long time for one to sit.
Old Sep 23, 2022 | 06:55 AM
74 Blacky's Avatar
74 Blacky
7th Gear
I haven’t checked the plugs yet because she just fired right up like nothing happened when I put fresh gas and a new battery/oil change. Luckily gas tank was bone dry when I parked it. Runs real good except a small gas leak at throttle.
The smoke is pretty bad at idle but not so much when I rev it up.
Old Sep 23, 2022 | 02:33 PM
440 sixpack
Make sure your PCV is baffled if they're not stock valve covers/.
SpeedJunky
Jan 7, 2009 05:04 PM
FoothillFord
May 22, 2008 09:49 PM
brent65
Oct 29, 2003 07:08 AM
lsrjf
Jul 27, 2002 08:37 PM
steakman_usaf
Sep 23, 2000 08:04 PM
