white smoke
Old Jul 17, 2002 | 12:50 PM
lsrjf's Avatar
lsrjf
white smoke
I have a 68 390 or 360 not sure which but it has been rebuilt for a while now but ever since I had it rebuilt it has smoked a little out the right side it is white smoke and smells like gas not oil but i have adjusted the carb, rebuilt the carb, replaced the carb,and havent had any luck. what should i try im not sure where to look next im thinking of changeing the intake to a 4v and maybe rebuilding the heads anyone with any ideas
Thanks Jeff
Old Jul 18, 2002 | 10:36 AM
Fastcat's Avatar
Fastcat
white smoke
Does it smoke all the time? May be rings. Or just when you start it? Probably a head issue. Or when your accelerating? Possably rings. Or when you let off going down a hill? May be a ring problem. Is it possable steam? Head gasket leak. I would take it to someone that can run a compression test on it.
Old Jul 18, 2002 | 11:19 AM
lsrjf's Avatar
lsrjf
white smoke
it smokes when it first starts a lot like it is flooded but just on one side then at idel it smokes just a little when you really race the motor up it smokes a lot just out one side. what i cant understand is that it smells like gas usually you can tell if it is oil smoke .Also when adjusting on the carb you cant really tell any difference until you get the screws ran all the way in then it will start to die but after you run the screws out just a turn or two it really dosent change the way that it runs by the way i have the ford two barrel.
thanks Jeff
Old Jul 18, 2002 | 11:35 AM
econodrag's Avatar
econodrag
white smoke
I have white smoke comming from my truck also.........OH wait a minute thats comming from my tires....LOL. Anyways I would take fast cats advice and run a compression test and rule out any thing in the combustion chamber. You may even want to do a leak down test also. Good luck. Tony
Old Jul 23, 2002 | 02:30 AM
Scotty1's Avatar
Scotty1
white smoke
As a general rule White smoke is usually OIL. Black Is usually Fuel. This not always true but usually it is right on. The reason it smells like Gasoline could be the fact that it is running rich. but that might not be what is causing it to smoke. I would agree to check the rings and so on. Who did the rebuild?? How long ago?? Were the rings changed?? Was the rebuild just a gasket change?? All these could help to answer the question of why it is smoking.
Scott
Old Jul 23, 2002 | 09:45 PM
CACWBY's Avatar
CACWBY
white smoke
[updated:LAST EDITED ON 23-Jul-02 AT 10:46 PM (EST)]Hello, if it is actually White (not light blue-which is oil=bad rings, or worn valve guides, both=time for overhaul)smoke then you have either a bad or blown head gasket, crack in head or block, any of which can be worse as engine warms up. It also could be the top of block (Deck) not being square (or warped). LOL, CACWBY in WI
Old Jul 24, 2002 | 11:51 PM
Ratsmoker's Avatar
Ratsmoker
white smoke
Old Jul 27, 2002 | 04:57 PM
hated_in_seattle's Avatar
hated_in_seattle
white smoke
if oil on dipstick smells like gas, could be fuel pump. it happened to me on another vehicle and tons of white smoke came out!
Old Jul 27, 2002 | 08:37 PM
lsrjf's Avatar
lsrjf
white smoke
sorry it has taken me so long to get back to you guys been working a lot of hours.I had to put a water pump on my truck today It has been bad for a while and since i havent really needed the truck for a while i havent been really serious about getting it fixed but i did get it done today after i got the pump on i started it up and it was smoking as usual today really a little worse i took the truck down the road and the further that i went the less it smoked then i noticed the temp gague and it was over heating so i hurried back home the thermostat was stuck took the thermostat out back down the road again over heating stoped and no smoke!!!!!!! So now what was causeing the smoke stuck ring or what? I really didnt give enough info about the rebuild it was a complete rebuild bored 40 over but i have to admit that i didnt rebuild it myself and the guy that did knows little or nothing about fords so im not really sure what was done and what wasnt am i to assume that if it smokes on start up in the morning that it is head work that needs to be done.
thanks for all the help jeff
jeff gammon
16
Feb 29, 2012 07:36 PM
jvwhittaker
Aug 13, 2010 09:20 AM
nickdellamore
Aug 3, 2010 12:41 AM
knappo_99
Nov 7, 2006 10:03 PM
broncoIIdon
Bronco II
Sep 20, 2003 01:55 AM
