Sponsored by: Real Truck
Remote start question
Old Sep 19, 2022 | 02:09 PM
Pappy3831's Avatar
Pappy3831
4wd Low
I used my remote start on my 2012 f350 a few times and it seems like it was messing up my ac. It would blow hot. Or out of the defrost vents. I quit using the remote start and have t had any issues knock on wood. Anybody else run into issues like this?
Old Sep 20, 2022 | 11:30 AM
5851a's Avatar
5851a
Is this the factory in the key remote start? The factory system will do whatever it can to return the interior temp to what it sensed it was on last shutdown. When you get in and turn your key it should return to whatever setting you have made on control panel.
Old Sep 20, 2022 | 11:32 AM
Pappy3831's Avatar
Pappy3831
4wd Low
Yes it is the factory key. I would use the remote start and then when I get in the vehicle and put the key in and turn it on is when everything screws up. The ac shuts off and then it’s a crap shoot as to what it’s going to do. I quit using the remote start and haven’t had any issues with the ac since.
Old Sep 20, 2022 | 04:32 PM
5851a's Avatar
5851a
Seems odd it acts crazy, mine is just whatever the last temp was even after winter storage. I'm a type that needs a window cracked open and some fresh air, so if I store in the fall and heat is cranked to like 80 so I have warm toes. Next spring fire it up on a nice spring morning, yep it's cranking it up to 80 on remote start. Works for me after I understood it's limitations. The limitation I can't understand is needing an oil change reminder after hibernation for 6 months and less than 10 miles on last reset and change. I don't understand but live with it.
RSV
Dec 19, 2018 12:08 PM
Aggie8098
2015 - 2020 F150
16
Jun 8, 2018 12:34 PM
mpally
2009 - 2014 F150
Dec 6, 2012 07:46 PM
SlickYamaha
Nov 22, 2011 08:12 PM
Big-Red-Lariat
2009 - 2014 F150
Jul 24, 2011 04:47 PM
